Try disconnecting and re-applying power, then do rinse and descale procedure as from manual. You may need to keep adding water while performing the procedure.
For some reason, people don't think too often about how dirty the ventilation system is, even though it is essentially the air they breathe indoors. I think it is very important to at least sometimes do Ventilation smoke test, and also contact experienced specialists who can quickly and efficiently clean the ventilation. Such services are also provided by Grease Gone.
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display. Ventilate after descale is normal.
When it says to ventilate, it is asking you to prime the pump. Put acup
under the panarello wand ( the steamer/frother) to catch thedischarged
water and press the hot water button (upper left button onmy machine).
Wait until air stops coming out with the water, usually3-5 ounces, and
then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
I want to close the ventilation system because in a daily bases I'm passing an area where the smell is very bad, and it pass through the ventilation even if it is closed, this is because it is actually not closing since there is a loose in the rubber of the ventilation window.
I'd like to close it for good.
regarding the disadvantage, I live in the middle east where there is no freezing wheather. and when I want to ventilate the car, I need just to open the car windows!
how to get the MAP of the ventilation system of my CAMRY 1999 GLi, so I know what to do?
turn the hot water / steam knob on to 'ventilate' the pressure from the machine. The ventilate /overtemperature message will disappear when ready (few seconds usually)
