Question about GE JES1238 Microwave Oven
Microwave works but won't heat
Microwave is 2 years old. Everything is working but it won't heat. Was working 15 hours ago and no storm or anything to interfere. I'm hesistant to pay the $70 service fee when I may end of buying a new one. Thanks for any insight. microwave count down but does not heat no sound that it is working light is working ok. replace the magneto still would not work
  • William Miller
    William Miller May 11, 2010
    Do the inside light and turntable both come on when you try to cook?
    Is it making any unusual noise or is it louder or quieter than normal?
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
iooit
Posted on Sep 30, 2010
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave works but won't heat
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. GE microwaves come with a mini service manual inside, which is very helpful. Since it's only 2 years old, the magnetron would still be covered under warranty, but you would have to pay labor and service call charges. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Otherwise, if you pull it from the wall yourself and take it in for repair, you can save about $50 or so. It is a 2-person job since it's heavy and awkward, and it helps if you have the original installation instructions. Feel free to follow up here if you need more help. We appreciate your thoughtful rating of our reply.
Posted on Sep 28, 2007
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Appliance will not heat,but operates
The problem is in the magnetron the heart of the system, or the inverter board, if microwave oven is 7 years old or less.
Jun 08, 2012 | Magic Chef CMV1000B Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. We used it about an...
Usually when it doesn't het there is a problem with either the magnetron or one of the power tranistors. You would have to get a shop to tell you what the problem is as it can be a few things. If you have warrenty either maytags or from the store just find out from the store/maytag where the repair depot is. They will either repair or replace it. If no warrenty then don;t do anything without getting an estimate. It may be just as cheap to buy a new microwave.
Aug 12, 2010 | Maytag MMC5000 Microwave Oven
Doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Jul 01, 2010 | Amana ACO1860 Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Kenmore Microwave model 721.80019 does not heat
Hi
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. As there was power loss due to storm so I believe it could either be the the high voltage circuitry, or the circuit board . To resolve this problem, you need the assistance of a qualified appliance repair technician.
Please do rate the solution as FixYa and revert for further assitance.
Thanks
Rylee
Jun 07, 2009 | Kenmore Microwave Ovens
Microwave lights and buttons work but doesn't heat up anything
When you start the microwave say for 1 minute. Listen closely when you hit start, the light should come on and about a 1/2 second later you should hear a little click and a slight hum. This means the controller is turning on the high voltage transformer and that part of it is working. My guess is that the magnatron is bad. That's the most common problems with all brands of microwaves. The mat on the top should not have caused the problem since the microwave has heat shutdowns in it. I would say that it's a 90% chance it's the magnatron. Most microwaves have a 5 year warranty on that part. Look at your owners manual. Good luck.
Scott
Jan 23, 2009 | Amana Radarange Microwave Oven
GE JVM 1650BB does not heat...
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.Mine had a ten year warranty on parts.
Oct 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
Re: microwave does not heat
Is very unlikely that there could be any other electrical failure since everything else seems to be working.
If you are able to fix it yourself then is way more cheaper just to buy the magnetron.
Click here to find the magnetron.
Before you do any work on this device, please click here to know how to discharge the high voltage capacitor and other safety concerns when working with devices that generate high voltages.
I would say is not worth it to spend more then $100.00 for a 5+ years old microwave.
Good Luck.
Jul 16, 2008 | Whirlpool MH6150XM Microwave Oven
Aug 05, 2007 | GE JVM1653 Microwave Oven
GE JES1238 Microwave Oven Logo
255 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
