Question about HP DeskJet 940c InkJet Printer
HELP! My printer is printing these incription codes or something?! I don''t know what to do to stop it.
  • kivuli Aug 11, 2008
    my printer either prints garbage in one line or prints the sent job and stops after printing a quarter way. please help!!
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Those are blown drivers..
you'll need to uninstall them
go to www.hp.com for new ones for your model and operating system
re install
try it again
Posted on Aug 19, 2008
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
The printer just keeps printing an incripted code, then feeding blank paper & starting over again until it's out of paper. We have to turn it off in order not to use up all the receipt paper.
Hi Star Customer
Please make sure the printer is configured to use ESC/POS by opening the printer software and select ESC/POS mode.
Please contact support@star-emea.com for more information.
Star Technical Support.
Jul 26, 2011 | Star Micronics TSP100 Thermal Printer
I've been using OKIDATE MICROLINE 320 PRINTER at work. I was printing something and I realized that I was printing the wrong page so to stop printing, I simply turned off the power and waited....
You would have to cancel the current print job from your computer for it to stop. Assuming you have access to a computer that is connected to that printer, you will have to find that printer by going to Control Panel > Printers and Faxes > Oki ML 320 then right click, select "See What's Printing" and cancel Current print job (I am also assuming you are using windows). I really hope this helps, if not add a comment clarifying your question, thanks.
May 23, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Im having a serious issue tring to get my kyocera fs-c5030n to print. I try to print, and it doesnt prompt for a password, but all that comes out if the printer is invalid account id everything I try to...
1. Click Start > Printers and Faxes
2. Right click the Kyocera printer and select properties
3. Select the "Device Settings" tab
4. Click "User"
5. Enter your User Name and Department Code
6. Click OK, OK
If you don't know the User Name and Department Code, these can be programmed by using the "KMNet Viewer" software utility, you can download it from here:
http://www.kyocerasupport.co.uk/index/download_center.false.driver.FSC5025N._.EN.html#
May 04, 2011 | Kyocera FS-5025N Laser Printer
Printer is printing hidden codes
Are you using Word? If you are, then use the help section and search for "Revel Code". Once you find that, then turn them off and that should take care of the problem.
Don
Feb 18, 2010 | HP Deskjet 3845 InkJet Printer
Can't delete print jobs
If you are using a Windows platform then if you look at the bottom right of the screen you will see a printer icon. Double click on the icon and the print queue will be displayed. To cancel a print j0ob, highlight the job and then cancel it.
Don
Nov 18, 2009 | Dell 968 All-In-One Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Dell 964 printer is only printing grey bars
My printer has stopped printing anything but grey bars. I got a message saying that something was wrong with the alignment. could you help me?
Aug 23, 2008 | Dell Photo 964 All-In-One InkJet Printer
Black will not print
Hi springfield, From what you describe I don?t think it has anything to do with your printer drivers. I would try the following: -Run a couple of nozzle cleaning jobs. -If no change I would suspect a defective cartridge and would try a brand new HP cartridge. If these don?t work I?ll need some more details such as do you refill cartridges, buy remanufactured cartridges or use new HP. Also is this still under manufacturer?s warranty? I don?t want to suggest anything that would void it. Let us know what happens and please don?t forget to rate the posting.
Jan 23, 2007 | HP LaserJet 3300mfp All-In-One Printer
HP DeskJet 940c InkJet Printer Logo
Seeker5211
Seeker5211
