Possible that the drain valve/pump is faulty.Now this can be failure of the pump/valve or the pump is clogged with dirt and so does not work. You need to first check the voltages on the drain pump at the time of drain, if not present the program controller is faulty but if present the valve/pump is faulty. remove from the drain outlet hose fittings , remove the pump and clean or back-flush with jet water, test outside for the pump to work freely , if not the pump is faulty and must be replaced.
