Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
Xp wont load
I installed a whole new system inc new sata drive. when installing win xp it wont go past the screen of setup is starting windows.
  • 781 Answers
Go to BIOS setup check that sata is recognized also if you have an ide drive in computer it may not find the one to use I had to remove ide drive for windows to install
Posted on Aug 10, 2008
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
I want to install Windows XP on Sony Vaio VGN CS15GN B instead of Windows Vista but it is not happening kindly help
---------------> Perform a clean install of Windows XP 1)- Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
2)- When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
3)- At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4)- Read the Microsoft Software License Terms, and then press F8.
5)- Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
6)- Follow the instructions on the screen to complete the Windows XP Setup.
Note:- Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
May 25, 2011 | Computers & Internet
When i start win xp setup from wintousb software bcz i want to install win by usb after loading win files it gives blue death screen technical info:...
try going into the system setup or bios screen and see if you can find a setting for SATA Operation or SATA Mode for the hard drive. if you can find this, select ATA or AHCI and test the installation again. hope this helps.
Apr 16, 2011 | Computers & Internet
WHAT CAN USE TO REPLACE A MAXTOR 7Y250MO HARD DRIVE? IT IS IN A 6 1/2 YEAR OLD DELL DEMENSION XPS GEN 2 TOWER RUNNING WIN XP. THE OS CAN NO LONGER FIND THE DRIVE AND WILL NOT BOOT UP. I WOULD LIKE TO...
The Dell Dimension XPS GEN2 has support for both, IDE and SATA standards. Your Maxtor is SATA drive, you can use any SATA drive as replacement. You mentioned that the OS no longer find the drive, make sure that you load SATA drivers at your Windows XP reinstallation, maybe your old drive is not defective only not recognized in the installation process. You can download the floppy image with required drivers here, see SATA drivers section. When you start Windows installation, at the Windows Setup Screen you should see, at the bottom of the screen, a message saying "Press F6 if you need to install a third party SCSI or RAID driver." At that point press the F6 button and when the next screen appears press S key to specify an additional device. Select the drivers from the provided list(to load all drivers from the disk, beacuse I don't know which is yours as I don't know the content of the disk, repeat steps to specify additional device), after drivers load your hard drive should be recognized and you can continue installing the Windows XP operating system. Ignore these steps if your hard was already tested and confirmed that is defective. Good luck!
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Sep 26, 2010 | Dell Computers & Internet
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
Mar 18, 2009 | Microsoft Windows XP Professional for PC
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Cannot install Windows XP Professional on Acer Aspire 4720Z Laptop
yu need to go to the the bios before you start the installation and change the Sata hard disk mode to IDE.then it will detect the hard disk.
May 05, 2008 | Acer Aspire 5610-4648 Notebook
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
53 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
