Question about Frigidaire FRS26R4A Side by Side Refrigerator
Frigidaire side by side model# FRS6LR5EW6
The problem we are having is the refrigerator will not cool below 60 degrees and the freezer not below 40 degrees.F. Also,on the freezer side, ice is accumulating on the back wall at the approximate location where the defrost heater is shown to be located. Unit is only 1.5 years old; coils are clean; condenser fan and compressor are running ok. The problem started about 3 days ago, and seemed to gradually worsen each day. Any ideas and help would be appreciated. P.S. We have heard that there have been problems with the automatic defrost control kit assemblies on these models. This unit only came with a 1 year warranty, which is now out.
Need Help in SC....
  • michael387 Jan 28, 2009
    I noticed the freezer was not freezing my ice cream. I pulled the back panel off and sure enough there was a lot of ice around the defrost elements.
  • Anonymous Mar 19, 2014
    I have been told the freezer will not work properly if the outside temperature is below 55 degrees
  • 725 Answers
Sounds like a defrost problem or a plugged drain... to get it to work temporary defrost the freezer. Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks.
To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain.
The defrost systems is:
HEATER-DEFROST
THERMOSTAT-DEFROST
Adaptive defrost control
Start with the adaptive defrost control board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
Frigidaire - referance model FSC23F7DSB3
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A �d� in the freezer temperature window and �F� in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. �d� and �F� will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Heater / Thermostat
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Posted on Aug 10, 2008
Frigidaire problems
Use the link below to view and read the user manual. If this is a used refrigerator it is possible that there may be a problem but it should be minor. The refrigerator section is cooled by air from the freezer. This problem is usually caused be excessive frost but you should not have frost buildup in only 24 hours.
There is also parts lists and diagrams.on the site.
I am also including a link to youtube videos about refrigerator problems.
FGHT1832PF0 FRIGIDAIRE REFRIGERATOR Manual
Frigidaire FGHT1832PF freezer cold refrigerator warm YouTube
Sep 04, 2014 | Frigidaire FGHT1832PF Gallery Series...
Frigidaire refrigerator not cooling at times
Click this link below for problemRefrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
---------This will help.Thanks.
Feb 09, 2012 | Frigidaire Refrigerators
My refrigerator is only cooling to 60 degrees with the thermostat at the coldest setting. the freezer works fine
You have a defrost problem.
http://www.appliancepartspros.com/Appliance-Parts/frigidaire-adc-iv-kit-item-number-ap4909015.aspx
Jun 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a Frigidaire side by side, 32 or 33 cc. The cold side is running 60 degrees, but the freezer side is fine. Any suggestions? Kim
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Refrigerators
Refrigerator side won't go lower than 60 degrees. freezer side is okay.model FRS26ZTH04
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Frigidaire FRS266ZDSB Side by Side...
My frigidaire side by side isn't cooling properly,
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 21, 2010 | Frigidaire Freezer Refrigeration White...
How do you manually start timer on fisher paykel
We disconnected the refrigerator and took the back of the freezer apart. There we noticed ice had built up on the coils. After removing all the food, we let the freezer defrost for 3.5 hours. Then we connected it, and it started to cool down immediately. After 1 1/2 to 2 hours, the refrigerator was down below 40 degrees. All food was replaced, and now the refrigerator is working properly All of this was down to the Fisher Paykel Model E522BRM.
Aug 31, 2009 | Fisher and Paykel Active Smart E522B...
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
1,150 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
