Question about Foxconn MB KT600 600A01-6LRS Motherboard
Foxconn 600A01-6LRS FANS START BUT NOTHING ON screen
Hi i just bought a Foxconn 600A01-6LRS mobo and ive plugged everything in but nothing shows up on the screen the fans turn on and hard drive spins up so it is defanatly not the psu. I have tried a tv on s video out and that just lights up for a second and then it goes blank. the monitors dont do anything. any help would be appriciated seeing as i paid $120 for it and would like to get it going. also would it be smart to buy a diagnostic card. thanks
J.man
  • Anonymous Aug 10, 2008
    its agp. ive tried a 4x nvidia geforce 440 mx and a tnt 2. the mobo suports 8x agp
  • daisy738 Oct 01, 2008
    I have a FOXCONN 600A01-6LRS motherboard and noting is on the screen, no video, no beep codes nothin but CPU fan running.Tried several power supplies, same result can you helP
  • 781 Answers
Does your video card suit the motherboard they have different ratings
2X 4X 8X 16X if yours is a 16X and you fit to any lower number it will not work this is for both AGP and PCI-E
Posted on Aug 10, 2008
6ya staff
SOURCE:
My foxconn motherboard is power on but there is no signal on the screen and no bios
Hi ' first try to check all wire if it is insert properly but if still not working good the cause is sometimes errors on hard drive to boot your system because of bad sectors ' try to reinstall a new operating system,thanks for using fixya. . . . .
Sep 01, 2012 | Intel Foxconn Motherboard
I have a foxconn mobo model g31mv and has a problem with the video, well it shows nothing at all. Ive changed the memory, power supply, jumped the bios and check all the wiring and nothing. So.. what...
Try this motherboard troubleshooting beeping code first.
No beeping means short circuit,loose parts.
One beep means everything is working good.
Two beeps means CMOS error.
One long beeps,two short beeps means video problem
Three long beeps means keyboard error.
Continuous long beeps means memory not detected.
Continuous Hi-Lo beeps means processor overheat,loose blower fan heat sink.
If no beeps need to change capacitor parts of motherboard for burn, short and open leakage.
Jul 16, 2011 | Foxconn G31MV-K Motherboard
Problems with Abit NF-M2S Motherboard?
hi there..
i also have the same mobo like yours. i also thinking to upgrade my old processor with better one..
made some quick research.. i would say the mobo unable to support the new processor. checked the BIOS update n CPU support list in Abit's site..
didn't show X4 processor is supported :(
Jan 15, 2010 | Abit NF-M2S Motherboard
Installed new equipment, now monitor is blank
just dump everything and buy a branded new PC....
u will be increasing ur BP....it;s not worth this much effort....
the kind of work u have done...it seems ur an expert so u urself work it out what's wrong...and where did u make a mistake...
i guess ur CPU and MB are not getting along....some issue with ur integration.....of all parts....
Dec 18, 2009 | Computers & Internet
Foxconn MoBo 947p7aa & keyboard lockup
Check if the processor temperature. ... sounds like that could be the problem. It would cause the computer to FREEZE the moment you start "working" on it because then the processor must do it's thing but it instantly overheats because either the processor cooler fan is'nt functioning correctly or the thermal paste has hardened and no longer offers a "connection" between the processor and the fan
Jul 06, 2009 | Foxconn (865G7MC-ES) Motherboard
Alienware c51xem2aa out the box wont turn on
If there was a spark and it smelled, something probably burned through. If I were you, I'd send it back to Alienware and request a new one. Even if you could fix this now, the risk of it breaking again in the future is much bigger. I hope you'll get your new PC fast, Yannick.
Jun 07, 2009 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | ASUS P5PE-VM Motherboard
Foxconn mobo
try to look on the jumper settings on the motherboard before you upgrade your proccessor maybe they need to be adjusted.tryb to put back the one wich was there and see what happens.how many beeps does your computer makes when you switch in on?if it makes more than one then your proccessor is not compatible with the board.a computer should beep once whenevever its switched on
Sep 06, 2008 | Foxconn 945GZ7MC-RS2H Motherboard
My mother board AOpen MX4LR, socket 478, dead
bad mobo or psp is bad try psp for now lock down mobo tight also losee no good
Jan 06, 2008 | AOpen (MX4SGI4DN2PRE) Motherboard
Won't boot or start, fans and leds work
Are you hearing any beeps when you start it up?
Dec 17, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Computers & Internet Logo
211 people viewed this question
Top Foxconn Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
