Toshiba A300. One month old. With the battery installed, when AC power is switched off or disconnected, computer turns off immediately. With no AC power, and with the battery installed, computer will not switch on. When battery installed, computer indicates that the battery is fully charged.
  • 3,051 Answers
If you can get the computer to start up go intop the control;e panel and look for the power options check to see what the power settings are set at sometimes the settings are set that if the computer uses only a little bit of power from the battery it will shut down so i always have my toshiba set at around 60% than it will shut down ok please keep me posted on this you have a lot of options here thankyou
Posted on Aug 09, 2008
    Problem Solver:
  • 30 Answers
The PC suppose to still be on warranty, so you can go and returned. When you bougth it, you need to charged it for a period of 12 hours. If the battery charging icons indicates that is charging, maybe the laptop terminals are not working and you need to take it to the store for that.
What wrong with my computer?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 20, 2013 | Toshiba Satellite L750 Notebook
My a300 laptop touchpad is not working
Hi
Disconnect power, remove and replace battery. Static build up or something.Or Download the touchpad on off utility, incase it's been turned off.
Jun 22, 2011 | Toshiba Satellite A300-0CF035 Notebook
I was working on my brand new toshiba (5 hours old) Got the message to plug in the power as battery was low, as I did that the computer switched off and I can not get it on again even with the power cord.
Suggest you take it back immediately to the retailer for an exchange as this would be the simplest solution. If you are not satisfied and you paid by credit card, contact your credit card company.
Feb 17, 2011 | Toshiba Satellite A300-0CF035 Notebook
How to reset bios password on toshiba satellite A300? pls help..
Satellite Pro A300 (PSAJ1E-)
Remove battery and disconnect the AC-adapter then short pad G1 for a minimum of 30 seconds
with a flat-blade screwdriver, the pad is located under the memory module.
This can be accessed from the base of the notebook
Jan 26, 2011 | Toshiba Satellite A300-0CF035 Notebook
Hello, Can I install a 512MB DDR DIMM, N mem stick taken out of my Dell Desktop into a Toshiba Satellite A15, S129 laptop? Thanks, RD
You can try, without fear of having your laptop "blow-up".
Turn your laptop off.
Remove the battery.
Physically, does the RAM fit into the RAM slot? If not, the answer is 'no' -- most "desktop" RAM is much bigger than most "notebook" RAM.
If it fits, connect the AC power, and turn the computer on.
If it beeps wildly, or does not beep at all, the RAM is incompatible.
Disconnect the AC power.
Remove the RAM.
Re-insert the "old" RAM.
Re-insert the battery.
Reconnect the AC power.
Do a Google-search for "RAM upgrade Satellite A15" to find sellers that sell compatible RAM.
Oct 10, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba a300 softtouch lights
The lights can be turned on and off thru the bios and thru hw setup program on the pc
Aug 06, 2009 | Computers & Internet
How to start up my computer
take out the battery and put it back in and the manually turn on your pc
May 28, 2009 | Toshiba Satellite A300-0CF035 Notebook
Satellite a300 wont install windows (brand new)
turn off the computer and disconnect the battery . wait like half an hour. put it back in you have to wait a few minutes for the battery to finish charging then turn it on . this should help. the menu will pop up after you type your password in .
Mar 15, 2009 | Toshiba Satellite A300-0CF035 Notebook
Toshiba's A135-S4527 Battery isn't working anymore
Have the battery checked or better yet, replaced. Prolonged use might damage the charging circuitry of your machine.
Jan 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
