Question about Philips DVDR3575H/37
Can't finalise dvd containing AVI movies copied from USB
It will only allow me finalise DVD containing recordings from TV. Therefore DVD won't play in any other machine unless finalised
regards,
Ray.
  • 8,596 Answers
I would use your PC to finalize discs containing AVI files. There just isn't a way to do it from the Philips. I personally use Dr. Divx, but there are many programs out there that will do this.
Posted on Sep 04, 2008
Panasonic DVD S48 - DVD player how to play movies over usb
Yes, I know Panasonic DVD S48, if your movie file is right divx avi movie file, you can directly transfer the divx avi movie file to your usb disk and play on your Panasonic DVD S48, but if your movie files isn\'t divx avi movie file, you have to use a right software to convert your movies to right divx avi movies, then transfer to your usb disk, convert any movies to divx avi movies.
Dec 06, 2013 | Panasonic DVD-S48 DVD Player
How can I show my DVD-R(Memorex) on my televison?
I assume you mean that your current DVD player won't play this DVD?
There are 3 reasons that it won't play. One that the disc is faulty and therefore won't play on any machine. Two that the disc has a scratch or has marks on it. You can look at ways to clean the disc on-line!
3 That it was not finalised on the machine that it was recorded on. If you current player is a + machine it won't play the disc if it is unfinalised. You will need to use the old machine to finalise the disc or another "-" disc recorder to do it - if it will accept the disc! Otherwise if the old DVD recorder is no longer with you, then your only hope to save the disc is to find another model of your old recorder to do it on. If it was a common model someone might let you finalise the disc!
Feb 21, 2013 | Panasonic Original Pansonic Tv Vcr Dvd...
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
Dvd with usb port can not play avi
good day,
hope this link below will solve your problem.
nokia
May 29, 2010 | SanDisk Sansa e260 MP3 Player
When I record on DVD +RW disc from my other Tv and try to play it on my combie tv ,it will only play if my disc is finalised. so if I only record 30 mins and have to finalise ,I am wasting the disc. Why...
Some tv's are not capeable of reading Rewritable disks. By finalising the disk you are basically making it a non re-writable and thus allowing your other tv to read it.
Jul 16, 2009 | Televison & Video
Difficulty playing DVD movie clips
Hi, it depends on the type of movie clips you have on the disk. its possible they maybe avi files. To play on most dvd players you would need to convert them to mpeg 2 which is the format for dvd movies,you can google for software, or if you need more help go to videohelp.com. Normski
Apr 16, 2009 | Intervideo WinDVD 4.0 for PC
Recorded DVD will not play in another player
Hey,
Maybe the format of your recorded movie didnt support your player..check out your manual for the supported formats and check the format of your recorded movie.If any of the format in the manual matches your movie format then it will definitely play..
please rate my suggestion..
Apr 15, 2009 | Televison & Video
Recorded movie on dvd-rw will not play on another player
the best format to buy is the DVD-R but make sure your disc has been finalised if you reinsert your disc on the functions screen you should see finalise this is essential for compatible playback hope this helps regards Jim
Mar 26, 2009 | Televison & Video
Dvd's burned on one machine, can they be finalized on another machind to play
No, it must be finalised on the machine it was recorded on.Try copying on your pc then reburn it.
Oct 23, 2008 | RCA BD20TF10 20 in. TV/DVD Combo
AWA DR620 DVD Recorder - after dubbing to a blank DVD, it does NOT play on another DVD. I was expecting an .avi output, but my laptop does not show any file THANKS!
Are the DVD's finalised?
I found with mine I had to go into the disc menu and finalise the DVD's after writing them.
May 03, 2008 | Televison & Video
Philips DVDR3575H/37 Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
