Question about Amana Heating & Cooling
I have an amana cental a/c unit that i need wiring schematics on capacitors. unit model #ARCF30U01D SERIAL #9206159643 MFG #P9885203C
bobotfel
  • 236 Answers
SOURCE: i need to wire up a capacitor to a aircondition unit
If it is a dual capacitor this is the connections.
Posted on Mar 21, 2008
  • 20 Answers
SOURCE: Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
Posted on Jul 23, 2008
  • 306 Answers
SOURCE: model#SRCF30U01D. Serial#920-629-3049.
Are the wires going to capacitor correct. You have two sides to the capacitor one side is compressor or herm as stated on top the fan. should have one wire only on fan side then two wires to the common side and one wire to herm side. trace out the wires I'm sure it's electrical and make sure you can see that it does in fact have a dual capacitor. Turn off all electrical supply before even touching this as you are around some big voltage. I do this everyday and I won't even get close unless I pull the safety disconnect on the side of the house. Get back to me and can help further. Ken
Posted on Aug 22, 2009
  • 1230 Answers
SOURCE: I need schematics for an Amana Packaged Heat Pump
http://www.dnmech.com/lit/RT6331003.pdf
try this web site. I believe this is the manual you are looking for.
Hope this helps.
Posted on Feb 03, 2010
wise_jf
  • 66 Answers
SOURCE: NEED WIRING INSTRUCTION FOR CAPACITOR FOR
On top of the capacitor you will find the terminals marked. One will say C, or Com. The others will be marked fan and herm. There will be a hot wire going to C. Usually this comes of the top of the contactor and is red. Find the wire that runs to the compressor. It will likely be yellow. This will hook to the Herm. Next find the fan wire (probably brown) it will hook to the fan. Hope this helps.
Posted on Jul 14, 2010
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
Schematic missing - need to know which cond unit
Black wire goes to contactor. On your capacitor the brown wire goes on one side the blue and the other wire from your contactor goes on the other sideof the capacitor. Russ
Aug 07, 2009 | Heating & Cooling
Amana control panel sparks
your panel shorted out
replace control panel and wire harness is my recommendation
Although depending on age, these two parts are quite costly the panel alone is 272$ retail
if you decide to buy it you can call amana 866-616-2664
to purchase them, or local dealer normally can sell you the parts
but with a major short like that id recommend replace, if you buy parts bring model, serial, and MFG manufacturing number starting PALW
May 02, 2008 | Washing Machines
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
