Question about Samsung HCM4215W 42" Rear Projection Television
Help which site can i order samsung convergence board?
  • Samsung Master
  • 8,617 Answers
You can get the board at the following link. If youre not sure which one you need leave them a email with your model number and what youre needing and they will respond back quickly with the correct board for your model, they also have free tech support to help you install it. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 10, 2008
I have a HCL473W with a 'concave' screen effect on 2 colors??
You don't need to replace the whole board, regardless of which board it may be mounted on. The STK IC convergence chips alone are all that need to be replaced. You can order them from a number of different online sites. You can try Alibaba.com. If you have any more questions, feel free to ask!
Nov 08, 2009 | Samsung HCL473W 47" Rear Projection...
Bow at top and bottom of screen
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Hope this may help;
Regards,
VOTIT
Aug 04, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung hcn4226wx/xaa red color out of focus
Ok first of all, the convergence board you are looking for is no longer available from Samsung, probably because of the large failure these boards are having. The only thing to do though would be to replace the convergence amp IC's on the convergence amp board. this will involve locating the convergence amp board, going to http://www.samsungparts.com, entering your model number, without the /xaa prefix. Locating the list of parts for this TV set, and getting the right convergence amp IC's for this TV set. The numbers for the convergence amps are STK-392-040. You will also need to get the service manual for this TV set to perform touchup convergence, as well as to realighn the magic focus into the memory of this TV set. If you have the ability to solder and unsolder, you should have no problem replacing thes convergence amp IC's. But i will have to say this, about 45% of these TV sets do still have a problem after the convergence IC's are replaced. this is usually due to the burnt ground return resustors on the convergence board, so be perpared to know how to read a scematic diagram in the service manual and to trouble shoot the board. There is no simple repair to this problem I'm afraid, with this Samsung TV set. But , if at any time, you feel lost in the repair of this set, do not continue, and call out a pro to assist you in the repair of this TV set. Good Luck with the repair of this TV set.
Jun 26, 2007 | Samsung HCN4226W 42" Rear Projection...
Coloring is off and there is a ghosting effect
Part # BP95-00142E is the correct convergence amp board for a model # HCN4226W. Part # BP94-00155A is listed as a "CG Amp assembly board" also, but is not correct for a model # HCN4226W. They are both basically convergence amp boards. Here's a link to order the original Samsung covergence amp board for this model (HCN4226W) from a major parts distributor:
Samsung HCN4226W Replacement Part Convergence Amp Board
Jan 30, 2009 | Televison & Video
Rear Projection Samsung w/ convergence out
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung HCN4226WX convergence problem
Having same problem
Part # BP95-00415B Convergence module board ??
Cant locate - 00142
Feb 16, 2008 | Samsung HCN4226W 42" Rear Projection...
Convergence issues?
most likely the convergence board.
Ordered complete convergence board, ask samsung for part number Convergence AMP PCB $108.44, from www.samsungparts.com
or could send it in to ptscorp.com for repair.
Dec 23, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung hcm4215w Convergence board problem
Use PANASONIC STK's.They are expensive,but they hold up!Safe,durable repairs require OEM or BETTER quality replacement parts.
Sep 27, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung HCN4226W Service Menu?? For convergence issue????
The resistors on the new module are not 100% Identical in resistance to the originals on your board, to access the svc menu you will want a service manual and will require some patience. It can be tricky I would personally call a repairman with convergence in mind. Or order a manual and read the conv section several times. http://www.eserviceinfo.com/index.php?what=search2 Is one site, might have to purchase one.
Jul 06, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
