Dell inspiron 1501 laptop screen has vertical lines in middle of screen, have taken apart to check connections but still there, any ideas ?
  • Anonymous Aug 22, 2008
    I m having a similar problem with my screen, except the vertical lines have widened and sometimes disappear only to reappear again wider.I had my brother take the screen apart to trouble shoot.There wasnt any evidence of water seepage.So far the best best solution is to buy another screen as i think the screens are designed to fail.
    Genius:
  • 1,027 Answers
If the display is ok on an external monitor, then the problem is probably a bad tab board (tab welds) and the lcd will have to be replaced. If the external display is the same as the lcd then the inverter board or video card is bad.
Posted on Aug 09, 2008
I have multiple vertical line on my screen. Sometimes it is better than others. Ideas?
Possible loose connection on the LCD cable. The connector is behind the LCD panel. There's a tutorial on how to take apart a LCD panel on http://www.bootmylaptop.com
Dec 15, 2010 | Dell Inspiron 5160 Notebook
LINES ON SCREEN
IS IT PERMANENT WHILE YOU ARE WORKING IN ANY APPLICATION, ONLY DESKTOP, OR ANYTHING, THEN IT IS PHYSICAL PROBLEM IN LCD SCREEN OF LAPTOP.
IF IT IS IN WARRANTY PERIOD, TAKE IT TO IT'S AUTHORIZED SERVICE STATION TO GET REPAIRED FREE !!!
OTHERWISE GET IT REPAIRED BY PAYING SERVICE CHARGE. IT WIIL COST YOU $50-$100.
May 06, 2010 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Laptop-6'' Red Vertical Line
The color red and especially red colored lines or a pinkish hue are indicative of an impending screen failure. The only other possibility is that the data cable on the left backside of the lcd panel may be loose at the socket or on the motherboard. 9 times out of 10 though, it is the lcd panel that it failing.
Jan 17, 2010 | Computers & Internet
My dell inspiron 1501 laptop has been flickeri ng colors or a lrge strip down middle , now half the screen is black with little color line
hello
This could be anything from the screen is dying or the inverter (electronic board that powers the screen' back light).
If you press slightly at the top of the screen, see if the lines will disappear or not, if it does then come back again; you might need to change your lcd.
hope it helped
TekSpotDotCoDotUK
Aug 26, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Touchpad locked up
Check the system setup F2 at start, and ensure the touchpad is enabled, next try an external mouse, see if it works.
If and external mouse works, the touch pad has failed and a new palmrest is needed.
Jul 29, 2009 | Computers & Internet
Aspire 5100 laptop White line appear across screen. when you adjust the screen or bend it slightly they will disappear. took apart screen and there are no loose connections. Any ideas?
It's usually the lcd cable. It has a short so when you move the screen back and forth you're "fixing" it.
Best thing to do is just look up the part number on the lcd wire and buy a replacement one on ebay. If that doesn't fix the problem it's the lcd, but based on what you've described all signs point to lcd cable.
May 11, 2009 | Dell Inspiron 1501 Notebook
Black vetical lines on the screen. how do u fix
You need to flash or update your computer's bios. if you have an inspiron 1501 go here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R174470&SystemID=INS_PNT_1501&servicetag=&os=WLH&osl=en&deviceid=13120&devlib=0&typecnt=0&vercnt=9&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=236967
read the installation instructions or print it. then download the file and follow the instructions. after restart. see if you still get the vertical lines.
Mar 02, 2009 | Dell Inspiron E1505 Notebook
Pink vertical line on the screan
Hello pse try to connect an ordinary screen to your computer and see if you have the same problem then...use both screens at the same time ...and see if your lcd is the same or not...please tell me how it went...good luck...be hearing from you...Ron
Feb 27, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
