Question about SPL Dynamics XL2-1600 Car Audio Amplifier
Spl car audio ampli ext-2000d no power comsuption
TITLE: car audio ampli
ASK: i only have a pik current during the charge of the input condensateurs when i connect them to my labo power 12V.
all the components seems good, no breakdows components.
I cannot see any fuse also and the 2 leds of the front panel are off.
Thank you to answer
  • 631 Answers
Read through the following page (particularly the section on troubleshooting a dead amp).
Amplifier Repair Primer
Let me know if you have any other questions.
Posted on Aug 10, 2008
MY SOUNDCRAFT EFX8 IS CAUSING MY AMPLIFIER LIMITER TO KICK IN, AND CAUSING SOUND CUT OUT
Usually is because the signal exceed the input limit of the ampli.
I don't know which ampli do you use, but it should be a pro ampli with balanced inputs correctly able to manage +4 dB professional signals.
Try not to exceed 0dB in the master section of your mixer and let me know.
Oct 14, 2015 | Soundcraft Music
I want to build a box for my kappa subs and i need to know what specs would make them sound great. they are goin in my 97 chevy ext cab truck. the box is going to be my back seat also
http://manuals.harman.com/INF/CAR/Boxes%20and%20Parameters/1001dvc.pdf
Not knowing your musical preference, take a look at this spec sheet and pick the sound you'd most like. The bandpass design usually gives the most SPL, but a larger box is probably deeper while still having good volume. Some audio purists say a sealed box sounds the best, subjectively, but the SPL isn't as great.
Nov 08, 2010 | Infinity KAPPA 100.1DVC Car Speaker
How to use computer of average comsuption, average speed, ext temp ?
if my memory serves me right,if you zero all the readings before your trip then when you get to your destination you can read off the readings.thats it.(ext temp dont have a clue,except its ON permanently)
Nov 04, 2010 | 1978 Ford Granada
How do i connect my ipod to a Denon receiver? The receiver has a left & right audio input jacks under v aux input
de los cables macho- hembra tienen una entrada como de audifonos y las salidas en modo RCA blanco y rojo con 2 entradas conectalas en cualquier entrad posterior de tu ampli ya sea cd o en alguna auxiliar que diga play ok. saludos
May 02, 2010 | Yamaha HTR-5850 Receiver
How do i change the language on my pioneer avic-d3 player
here is the link to your manual:
http://www.pioneer.co.uk/uk/support/manuals/AVIC-D3/index.html
Setting the language
You can set a desired subtitle, audio and menu
language. If the selected language is recorded on
the Disc, subtitles, audio and menu are displayed
in that language.
1 Touch “Language” and then touch
“Subtitle Language”, “Audio Language”
or “Menu Language”.
Each language menu is displayed and the currently
set language is selected.
2 Touch the desired language.
When you select “Others”, a language code
input display is shown. Input the four digit
code of the desired language then touch
Enter”.
➲ “Language Code Chart for DVD” ➞
Page 114
from the manual:
English (en), 0514
❒ If the selected language is not recorded on
the disc, the default language specified on
the disc is output and displayed.
❒ You can also switch the subtitle and audio
language by touching “S.Title” or “Audio
during playback.
➲ “Changing the subtitle language during
playback (Multi-subtitle)” ➞ Page 75
➲ Changing audio language during playback
(Multi-audio) ➞ Page 75
❒ Even if you use “S.Title” or “Audio” to
switch the subtitle or audio language, this
does not affect the settings here.
Setting assist subtitles on or off
Assist subtitles offer explanations for the aurally
impaired. However, they are only displayed if they
are recorded on the DVD.
You can turn assist subtitles on or off as desired.
1 Touch “Assist Subtitle”.
Touching “Assist Subtitle” switches
between “On” and “Off”.
Cheers!
Jan 11, 2010 | Pioneer AVIC-D3 Car DVD Player
I have an spl gorilla series 1250watt amp that blows fuses
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL BLOWS THE FUSE, THEN IT WILL NEED TO BE SERVICED. IF IT BLOWS THE FUSE BEFORE TURNING IT ON, THEN YOUR PROBLEM IS IN THE POWER SUPPLY SECTION. IF IT BLOWS THE FUSE AFTER ATTEMPTING TO TURN IT ON, THEN YOUR PROBLEM IS PROBABLY IN THE OUTPUT SECTION. ALSO KEEP IN MIND THAT THE P1'S ARE REALLY NOT RATED FOR THAT MUCH POWER AND YOU MAY HAVE DAMAGED THE VOICECOILS. BEFORE REINSTALLING THE AMPLIFIER, MAKE SURE TO CHECK THE SPEAKERS FOR SHORTED VOICECOILS OR YOU WILL POSSIBLY DAMAGE THE AMPLIFIER AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 19, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
SW700 does not start automaticly
It sounds like the audio sense circuit is either disabled or defective. This circuit has few components and should be easy to repair by any service shop. Expect a parts cost in the $10-$20 range at most. Include the local labor rate for the total repair cost.
Dan
Apr 04, 2008 | Jmlab SW700BK Speaker
Problems with the ampli
can i joine the ampli with computer
Oct 17, 2007 | Autotek XS-900.2 Car Audio Amplifier
SPL Dynamics XL2-1600 Car Audio Amplifier Logo
253 people viewed this question
Top SPL Dynamics Car Audio & Video Experts
xxxxxx xxx
Are you a SPL Dynamics Car Audio and Video Expert? Answer questions, earn points and help others
