Question about Waring WMK300 Professional Belgian Waffle Maker
Waffles stick in unit
If I use Pam cooking non stick spray after the unit heats up the first waffle does not stick. Every waffle thereafter sticks to the unit. The directions do not indicate spraying prior to every waffle. Is this required or am I doing something else incorrect?
  • Paul Proulx Aug 10, 2008
    I don't use butter or margarine but I do use canola oil (6 Tbs.) in the batter. This minimizes the cholesterol impact I have on my body. Cholesterol is a problem for me. Thanks for the suggestion. Is there anyone else who faces a similar problem and use vegetable or canola oil in their batter and is able to keep sticking from occurring?
  • 3piepers Nov 15, 2008
    We have had our Waring Waffle Maker for almost 2 years and have on occasion experienced the same sticking problem with the waffles. We have attempted to try a few different things. Each with varying results - some better than others. Here is what we have tried at different times: 1) Add 1/3 cup cooking oil to the waffle mixture. 2) Crisco the waffle skids prior to use first thing each time. 3) Spray Pam on the skids prior to each new waffle. Because I have misplaced my Waring instructional manual, I am not sure "what" the manufacture recommends. Does anyone have a "surefire" remedy for getting the waffles NOT to stick? Please advise.
If you add a 1/4 cup of melted butter or margarine to the waffle mix, they do not stick, mine don't stick at all. There is also a recipe using yeast, butter, etc, that makes excellent waffles, and they do not stick.
Posted on Aug 10, 2008
Need directios to use. waffle sticks to top and bottom
If it is a non stick waffle iron don't use a spray coating.
If it is a uncoated iron it is normal for them to stick for the first few uses. If you already have waffles stuck in the iron coat the stuck areas with cooking oil and reheat. Use a wooden or bamboo sewer to pick out the remains. Use cooking spray to coat the grids before cooking waffles. Try a different recipe. Some are more forgiving and don't stick as easily.
Jul 14, 2014 | Kitchen Appliances - Others
Sticking is a real problem no matter how well I season the plates,impossible to remove waffle on one piece
Putting cooking oil in the batter will help some. Use Pam (or similar) to help keep the waffles from sticking. Spray the bottom plate, add the batter, spray the top plate and close. I'm not sure why, but the first waffle is never as good as the ones after it. But this always works for us.
Hope this helps,
--W/D--
Jan 20, 2011 | Microwave Ovens
When using a toastmaster waffled maker do you have to use an oil or butter pan spray?
Normally you mix oil in with the batter, but this doesn't keep the waffles from sticking. Even non-stick waffle makers stick some. Use a light spray of Pam (or similar) on the bottom tray, add your batter than spray the top pan and close. This gives you your best shot at a perfect waffle!
Enjoy!
--W/D--
Jan 17, 2011 | Toastmaster 217 Cool Touch Belgian Waffle...
ProLine waffle maker sticking. Followed all direction from factory. No Pam used.
The plates on the waffle maker need to have some sort of cooking oil or butter to lubricate and prevent your waffle mix from sticking.
Spray some PAM on the plates once the correct temperature has been reached, or alternatively brush on a little melted butter or vegetable oil. Pour in your waffle mix and when cooked the waffle should lift straight off.
Jan 16, 2011 | KitchenAid Pro Line¿ Waffle Baker
How to clean the stove top waffler & keep waffles from sticking?
Best wasy to keep waffles from sticking is to spray the maker with a non stick food spray like "PAM". The other way is to increase the amount of oil in the batter, but that can affect the finished look.
Jan 10, 2011 | Nordic Ware 15040 Belgian Waffle Maker
Waffles sticking in a Salton wm-4.
Salton wm-4! one of the oldest waffle maker. The waffle is generally known to be difficult to clean. I would only advice you should always grease the plate before use. This helps make cleaning easy. You can also check our post on The Best Waffle Maker in 2017 The best waffle maker 2017 Easy buying guide Kitchenutilitypro
Sep 24, 2017 | Salton WM4 Waffle Maker
Waffles are separating when we open the plates
In my experience this is due to sticking on the plates. I spray a little cooking spray on them with each batch I make.
Maybe they arn't quite done.
Jul 12, 2009 | Waring WW150 Waffle Maker
The waffles stick although it is a non stick surface What are we doing wrong?
Even a non stick with all those surfaces(all the corners and ditches) is gona stick, try brushing with butter if you dont have a butter spay. Let me know how it cooks out goofballlovers
May 09, 2009 | Black & Decker WMB500 Belgian Waffle Maker
Waffle Iron Sticking...HELP
Try using 2 Tablespoons of oil in your recipe.
Mar 21, 2009 | Kitchen Appliances - Others
Seasoning Waffle Baker and Grill
FIrst, make sure there is some kind of fat or oil in the waffle batter recipe. This is the biggest difference between waffle and pancake batter. Go to Sams or a restaurant supply store and get a spray product like waffle-off. Spray lightly aftter every few waffles. Use lightly as heavy spray can cause build up. If you can't find this product use one of the PAM type sprays for BBQ grills or maybe an olive oil based product. Regular Pam sprays build up faster as they are not really designed for this. Don't try to wash the grids between uses as they need to keep the oil coating. (Like using a cast iron skillet) They will turn a dark brown. Just brush off crumbs or use a damp rag. Make sure the waffles are completely cooked as when not completely cooked they will seperate and be very difficult to remove. They are cooked when the steam stops coming from the sides. This will take 3 - 6 minutes. Don't preheat with the iron open or allow it to stand open for any longer than necessary. (It can overheat)
Apr 13, 2008 | Kitchen Appliances - Others
Waring WMK300 Professional Belgian Waffle Maker Logo
585 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
