I BOUGHT SYSTEM MECHANIC FROM WORLDSTART AND HAVE ENTERED THE USER ID AND SERIAL NUMBER ON THE SLEEVE MANY TIMES BUT THE PROMPT SAYS THERE IS AN ERROR CONNECTING TO THE INTERNET? i HAVE NOTHING WRONG WITH MY INTERNET CONNECTION, SO WHY WON'T THE SOFTWARE ALLOW ME TO INSTALL?
    Sergeant:
  • 226 Answers
IOLO software which is the company that makes System Mechanic has a very strong technique for testing serial #s before the software is installed. If the serial # fails that testing it will not be allowed to be installed. It is possible that IOLO has decided that your particular serial # is no longer valid due to possible use on the warez scene, i.e. it has been pirated. If that is the case then you will have to contact IOLO and let them know exactly where you got the software so they can futher investigate your purchase and the vericity of the agent you purchased from. Now you indicate that you have tried using this serial # several times and thus my next suggest may not work as a result, however it is still worth a try. TRY installing System Mechanic as shareware without the use of a serial #. With some softwares this will get into a limited mode of operation which may allow you to re-enter the serial # from the ' ABOUT ' screen. I doubt this will help with most IOLO softwares, but it is at least worth a shot. I have seen circumstances where trying to use an invalid serial
# can and will remove the future funtionality of IOLO software even with a GOOD serial #, meaning a person would have to remove all registry entries pertaining to IOLO software ( far beyond a simple de-installation ) before a ' good and valid ' serial # will effective. IOLO is very tough in this regard, one of the toughest around. One other thing that should be mentioned is the possibily of operating system corruption due to continued use of a bad serial #. While in most cases IOLO software would simply stop working, it is entirely possible that when it stops working it would also take the operating system with it. Other then the above circumstances, the only other possibility that I can think of for your serial not being validated is possibly a proxy issue if you are using a proxy or a firewall that is not letting communication with the IOLO website to occur. Please verify that your firewall, both hardware and software are permitting communication with the IOLO website
Posted on Aug 09, 2008
I have trouble doing windows vista registration on line after re-booting my system. My labtop has OEM and original version was installed. Can please assist in the registration. My 25 character are as...
Occasionally some Windows Vista user may need to activate his or her copy of Windows Vista operating system through phone activation, such as in situation where the computer is offline without Internet access. Other possible reason to use phone to activate instead of automatic online activation is failure or facing problem to activate Vista online, and user have to fallback to alternative.
For most users, activation process normally starts with attempt to activate Vista online. Online activation is simple and effective way to activate the copy of installed Vista, and when it fails or cannot activate successfully, then user can opt to activate by phone. If you want to skip and bypass online activation and go straight to activate Vista or Windows 7 by phone (i.e. in the case of offline PC with no Internet connection, do these steps:
  1. Click on Start Menu.
  2. Type slui.exe 4 into Start Search, and then press Enter.
  3. Go to step 10.
Normal activation procedures for Windows Vista, including fallback on phone activation:
  2. Right click on Computer and then click Properties, or open the Control Panel -> System and Maintenance -> System icon.
  3. Scroll down to the Windows activation section and click on the Activate Windows now link.
  4. Click on Activate Windows online now. Note: If you have not entered a product key during installation, the wizard will ask for a genuine serial key. If you uncertain of the serial number key used, or want to change the key used, click on Change product key link.
    And, this step must fails in order to go to phone activation.
  5. If the online activation process, user can continue to attempt to activate using automated phone system by clicking on Use the automated phone system to activate option.
  6. Select your location and click on Next button when prompt to find available phone numbers for activation.
  7. Click Continue if prompted with UAC dialog box, except for those who had disabled UAC.
  8. A local phone number or nearest telephone number will be displayed on screen, together with a set of Installation ID (54 numbers in total - 6 numbers in 9 groups) generated by Windows.
  9. Call the activation phone number.
  10. The call will be answered by automated voice response (AVR) system, that asked caller to speak, or if voice recognition failed, press the phone button to enter the Installation ID listed behind "Step 2?. The numbers needed to enter is a lot (54). If you want simpler way to do it, just speak and enter anything to let automated service fails, and then wait for the call to transfer to activation operator (a real human). Sometimes, if for some reason the Installation ID entered is not accepted by the AVR, your call may be transferred to human operator too. Note: The human operator may ask for the reason that causes requirement of reactivation or activation of Vista. Just tell the truth, e.g. hardware upgrade, transferring to new PC (for non-OEM edition only) and etc.
  11. No matter who you talk to (machine or human CSO), a set of Confirmation ID numbers which consists of 48 digits (6 numbers in 8 groups) will be given if Microsoft believes that your copy of Windows Vista is genuine and legitimate. Write down the Confirmation ID.
  12. Back to Windows Vista, type in the Confirmation ID given by the phone system into the wizard boxes after the "Step 3?, and then click on Next button.
  13. The activation should be successfully done with Activation was successful window appears. Click on Close button to quit.
Mar 13, 2011 | ASUS A8Fm PC Notebook
How do I set up a phone to display caller id? It displays on other phones in the office but not on mine.
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
May 03, 2010 | NorStar T7316E Telephone
Source code for book store management system in c++
Book Shop Management System
Introduction
BookMart is a book shop selling all varieties of books. It needs a console based application to manage its customer and business data.
Registration
Customers need to register before making any purchase. The registration system has the facility for the users to create their own user name and password. They can use the same for further communication with the system.
The user id and password should be stored in a file named “login.txt”.
The application should display the main menu as shown below
1. Login
2. New User Registration
0. Exit
Option 1: Login
If the user enters the option as 1, the user should be prompted to enter user id and password.
If the user has entered a valid user id and password, the message “Login Successful” should be displayed and the below menu options should be displayed.
1. View Books
2. Purchase
3. Back to Main Menu
If the user id and password does not match, then the message “Login Failed” should be displayed and the main menu should be displayed again.
Option 2: New User Registration
If the user enters the option as 2, the user should be prompted to enter a new user id and password. If that user id is not present in the “login.txt” file, the new details should be written to the file and the message “User Successfully Registered” should be printed else the message “Duplicate User ID” should be printed.
Option 0: Exit
If the user enters 0, the application should exit.
View Books
The book details should be maintained in a file named “book_master.txt”. The data should be stored as shown below.
Book ID ISBN Name Price Publisher
Sample Data
678 81-3434-343-3 Oliver Twist 500 PlaymorePublishers
When the user enters the option as 1, all the book details should be displayed on the screen with proper headings. For example, the output should be shown as below.
890 81-2456-343-4 The Tempest 800 Williams'sPublishers
Purchase
Users can purchase after valid registration with the system by providing the book id.
The number of available books is maintained in a file called “stock.txt”. This file will have the book id and quantity on stock. As purchases are made, the total count should be reduced in stock.txt. Stock.txt will have data as shown below.
678 50
890 70
Purchase details should be written to another file named “purchase.txt”. This file will have the details as follows.
Book ID Name User ID User Name Price
For example,
678 Oliver Twist 11 Shubha 500
Back to Main Menu
If the user enters 3, then the main menu should be displayed.
May 03, 2010 | Intel C++ Compiler For Windows 7.1 Full...
The seriel number provided on disk sleeve will not work.
The installation program for the WINDVR 3 program isn't looking for the serial number of the TV Tuner card. It's needing your registration serial number when you paid for the software. I found a serial number that worked for me (after looking for 4 hours!!). Just enter this serial number and it should work for you. Be sure and put something down for your company name, also. Here is the serial:
kC7G94GSAE08A0S
Jan 01, 2010 | Sabrent TV-PCIRC (TVPCIRC) Video Capture
After I have entered user id and password and the
Are you using the installer password or the admin password?
Jun 18, 2009 | NorStar T7316E Corded Phone
I can not install my purchased System Mechanic 7.0
Send a complain back to best buy and request for a change. Probably its broken.
Mar 30, 2009 | Iolo Technologies System Mechanic: Windows
Serial number for ulead video studio 8 no where on cd or sleeve
try this: http://download-crack-serial.com/software-crack.php?id=79168
Mar 11, 2009 | Ulead Videostudio 8 for PC
Lost works product key
you can go to my computer and there it will have your key. Good Luck
Jan 07, 2009 | Microsoft Works 8.0 for PC
I BOUBT YOUR SYSTEM MECHANIC AND WHEN I ENTERUSER ID AND SERIAL NUMBER IT SAYS INVAID
HI,
Please contact customer support no. of SYSTEM MECHANIC and tell them that you have been provided with a invalid code.They will give you a another new serial number.
Aug 14, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
