Question about Kenmore Kitchen Ranges
Kenmore range model c970-645431 does not maintain the correct oven temperature, it's either very high or very low.
SOURCE: my gas oven flame
BLOCKED JET MAYBE CAUSED BY FOOD SPILLAGE OR BLOCK IN PIPE TO JET
Posted on Jul 07, 2007
SOURCE: GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Posted on Sep 18, 2007
the flame failure device( FFD) may have malfunctioned,not allowing full volume of gas through to the burner.This is a safety feature, preventing full gas pressure to the oven straight away.
Posted on Oct 01, 2007
  • 969 Answers
SOURCE: need a repair manual for Kelvinator/Kenmore C970
TRY http://www.applianceaid.com/fault_codes.html
Posted on Nov 12, 2009
marka19
  • 1430 Answers
SOURCE: Oven lights ,but doesn't heat to preset temperature
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jun 17, 2010
Testimonial: "Exact problem and solution, Thanks"
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Apr 07, 2015 | Kenmore Kitchen Ranges
My kenmore elite oven is giving me a F30 error message. what is this code?
Sorry to read about your problem, I hope this helps you out.
f 30 is a the oven temperature sensor open, thats the probe in the oven area
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore Elite Stainless Steel 40" Dual...
I got an error code F2
Error F2 mean-Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Sep 29, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore Electric range does not maintain temperature setpoint.
How do you know the thermo sensor is working correctly when it gets hot?. No I think the thermal sensor is defective, it is cheap to buy.
May 04, 2017 | Kenmore Ovens
Kenmore SF367.....Contantly relighting during cooking?
This is a normal function of your gas range. I own a similar model and it operates the same way. The gas is not required to be on continuously to maintain the oven temperature and will relight periodically when the internal temperature drops below the prescribed set level.
Jul 04, 2009 | Whirlpool SF367 Gas Kitchen Range
Fitting
Not familiar with this particular range oven but the thermostat should look like a longinsh cylindrical closed end metalic tube. You may have to raise up the cooking surface to run the wires for a new thermostat. If your oven is cooking to high or too low you can try taking the bake temp control off the know and see if there is a fine adjustement for temperature. I use a temp probe with a very inexpensive Sears DVM (about 20 bucks at Sears) to adjust mine. You should give the oven a good 1/2 hour to heat up and another 1/2 hour between each adjustment. Remember, the oven temp will swing high and low to maintain the set temp. Hope this helps!
Mar 13, 2009 | Cannon Kitchen Ranges
Kenmore 9661 oven not maintaining proper temperature
HIIYou seem to have a problem with your oven probe sensor change that and you should be fine..good luck..
Jan 05, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Low oven temp.
sounds like a bad oven/bake ignitor. very common problem on all gas ranges.
Oct 17, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
193 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
