First thing I would consider is the=> W10135899 Defrost Control Board The first thing that stops is the compressor and fans most times when they go bad. You can find this board here=> ED5PVEXWS00 Control Panel Your control panel is found above the top shelf inside the fresh food compartment. Just unplug the power to refrigerator and lower the panel and where part 6 is in the photo is where the board is located. Most times when these boards burn out it creates this problem you described. Replacing that board should get you going and back to cooling normally. I will be here if you have other questions, Thanks, Sea Breeze
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
heatman101
