Question about VinoTemp (VT60GNV) Wine Cooler
Cannot close vinotemp
How can i get the door to shut? After opening i did not lock it, but now cannot close it. Am i doing something wrong?
The bottles are too long, and its probably hitting the glass. Try installing without it being double deep and see if that works.
Posted on Aug 11, 2008
I have a problem with my CDW60W13 Currys Essential dishwasher. The door will not click shut and springs open. I've had a look at the locking mechanism and can see nothing wrong.
There is usually a little latch on those mechanism to keep the door closed. If the latch breaks, the lock spring just pops the door back open when you attempt to close it.
I would repair the lock mechanism. Try for the part.
Aug 29, 2015 | Dishwashers
May tag Neptune 5500. The door locked light never comes on and door is not locked in any cycle. How do I test the switch/lock assembley? And is there a way to trick the machine into thinking that the door...
Grounding in a 120vac environment usually will cause a big spark and pop the circuit breaker. There is a possibility the latch is like a car door latch. If it somehow gets moved to the shut or latched position when the car door is open, it will never close and latch . The latch must be returned to it's normal door open position so that when closed it will latch securely.
Your machine's latch may be blocked by something acting like the car door latch described above. It may be the switch has broken and is the "culprit".
Mar 26, 2015 | Neptune Washing Machines
The interior lights won't shut off. Now also cannot open or close my windows or moonroof. Why and how can I fix this?
this sounds like the gem module which controls the operation of these. it may need to be reprogramed or replaced.
Aug 22, 2014 | 2007 Ford Fusion I4 SEL Sedan
Lg intellowasher wd1074fb
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
May 13, 2014 | Washing Machines
Rear door will not lock (or stay closed)
Remove the door panel to see what the problem is
inside the door with the lock mechanism
Mar 20, 2014 | 1995 Mazda 626
I have a 1997 ford thunderbird lx and the other day when i went to close the door when i got out it,it wuldnt shut i slammed it a couple times n it still wouldnt shut i really need help because i cant...
Here's something that might help you. Look at the door theres a little hook that grabs the striker on car, hold the door handle "open" and move the hook to the open position try to close the door. That should solve your problem. Hope that helps you.
Aug 05, 2011 | Ford Thunderbird Cars & Trucks
1994 pontiac sunbird 3.1 L V6...door locking system has gone haywire. I got home, opened the door to the car, and when I tried to close the door, it would not shut. Can I unhook the battery to reset the...
Your door locks will not prevent your doors from closing, you should be able to lock the doors by hand and then close them with no problem. Take a look on the car where the door closes there will be a brass rod, this is your striker, it is what holds the door shut. This striker lines up with a latch in the door, the latch is on a spring and when the door is open it should be up, when the door closes the spring closes the latch around the striker. Check to make sure the latch is up, if it is not the door(when you try to close it) will typically bounce back toward you. If the latch is down you maybe able to take a flat head screw driver or prying device and twist the latch back up, this should allow your door to close. If you open the latch and it immediately closes it will need to be replaced. Hope this gets you on the right track.
Sep 24, 2010 | 1994 Pontiac Sunbird
Door lock problems for 2003 Honda
sounds like the central locking motor is gone
Aug 12, 2009 | 2003 Honda Civic
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
VinoTemp (VT60GNV) Wine Cooler Logo
97 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
Level 1 Expert
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
