My UMX61 controller doesn't work. I bought a new USB plug and it says device drawing too much power and then it says it's going to shut down the USB port. Help?!
Put in a 9V battery or psu
Posted on Oct 24, 2008
My Tab will not start, I receive two different "draw failed" messages...if it is charging, it says, 'charging_7.jpg' draw failed. If the USB isn't plugged in the message is logo_expresso7.jpg draw fai
It sounds like the system image (operating software) got corupted and need to be re-installed. If you haven't got a backup image of your tablet, then you need to take it to a cell shop so they can re-install your OS (Operating System) software.
Mar 19, 2014 | Samsung - Galaxy Tab 2 7" 8gb Wifi
USB drawing too much power. I have a Canon MP460 all-in-one printer and a MacBook Pro on Snow Leopard. I just bought a new USB printer cable because my past two were not working in respect to this issue. I...
It may very well be drawing too much power from your laptop. These are fairly intolerant of devices that draw higher current like printers and some hard drives. You may need to get a small USB Self-powered hub. These are USB hub/splitters that have their own power supplies. These usually provide and tolerate higher power draw. To test, if you can connect the same printer to a desktop, you will likely see it works fine.
Sep 04, 2013 | Canon PIXMA MP490 Photo All-In-One Inkjet...
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
My Transcend 500GB is not working on my Dell Inspiron 1464 Windows 7 Home Basic But other USB devices like pendrive etc works fine. Also My Transcend 500 GB works fine on other machine has Windows 7...
The chances are that the portable drive is drawing more current fom the USB port then the port can supply. The current limitations on the USB ports are controlled electronically and if anything is connectedthat attempts to draw more power then the port can safely supply, the port is shut down.
You may have to use a USB power injector which you plug into the laptop and then plug the drive into that.
Mar 08, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Usb ports not recognized
Did this suddenly start to occur? Were they working before? If so, it is very simple - shut down computer, remove the battery and unplug any power source, wait a couple of minutes and reassemble and power up. Wala! I read all kinds of complicated instructions, started with the simple, and problem solved.
Feb 22, 2010 | Computers & Internet
USB Problem
USB devices are allowed to pull up to 400mA for each port. Unfortunately if you have a keyboard with the handy USB ports on it and you plug in your memory stick, you still are left with 400mA for your keyboard AND USB stick COMBINED. The keyboard will draw it's power from the USB port on the computer, so unless you have a device that has it's own power source, each port on your computer can draw no more than 400mA.
Jun 05, 2009 | Asrock P4I45GV R5 Motherboard
My averatec series 3200 notebook cant detect my usb device
The flash disk could be faulty, especially when it draws too much power, and this will cause the USB ports to shut down and the other USB devices won't work until the faulty device is removed.
Mar 11, 2009 | Averatec 3200 Notebook
Usb ports
  • The driver for the device is faulty. When you plug in a USB device, the computer should load and then configure the device without ever requesting a device driver. If the computer prompts you for a device driver, check the information that came with the device or go to the manufacturer's website to see if a driver is available.
  • The USB port might be defective. If the USB device is connected to a defective port, the device will not work. Try plugging the device into a different port. If all the USB ports are being used, unplug a device that you know works, and then plug the problem device into the port that device was using.
    If the device is plugged into a secondary USB hub with other USB devices, unplug the device from the hub, and then plug the device directly into a port on your computer.
  • Other USB devices might be drawing too much power from the hub. The device you are trying to use might require all the available power or bandwidth that your computer can provide. If other USB devices are connected to the computer and are drawing power from it, the first device might not work. If any other devices are drawing power from the hub, try disconnecting them, and then see if your device works. If this solves the problem, you might want to obtain a USB hub with its own power supply so that you have adequate power for all devices.
  • Oct 23, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
    Usb ports do not active
    One of the great features of USB devices is they can get power from the USB port. Plug in a thumb drive and it just works. The power for operating the thumb drive comes from the USB port. This works for small devices like a thumb drive but not something big like a scanner. The scanner need its own power supply.
    There could be several explinations for what you are seeing. Could be you are plugging in a device which is sucking too much power and the laptop is shutting it down. I would test the port with something small like a thumb drive and see if it works. If the thumb drive works but the other device does not a couple of things could be going on. Maybe the device just need power - is there a way to plug in a power supply? Or maybe the device is broken and shorted out. Does the device work on another computer?
    If something like a thumb drive does not work then it is a problem with the motherboard. Could be the USB ports are bad. It happens and there usually is no easy fix short or replacing the motherboard ($$$). Occasionally there is a BIOS setting for the USB ports. A bit of a long shot but worth a look.
    A possible work around would be to get a power USB hub. A hub plugs into a USB port and provides 4 or 7 USB ports. Good ones come with a power supply. When the hub is plugged into the power supply it does not draw power from the computer. Might solve your problem.
    Aug 23, 2008 | Acer Computers & Internet
    Qx5 microscope is shutting down.
    Does this device run from USB power.. (no plug in power supply) if so, the problem may just be that this device (not limited to microscopes) is trying to draw too much power, as not all USB ports are born equal (a common problem in laptops). the solution is to either buy a power supply for the microscope or get a "powered" USB hub (a usb hub with it's own plug top power supply) I hope this helps
    May 25, 2007 | Digital Blue QX5 Microscope
    Computers & Internet Logo
    145 people viewed this question
    David Payne
    David Payne
