Question about NexxTech NSMODX21
Modem not recognized when coming out of hibernation
NexxTech NSMODX21 - modem seems to work normaly EXCEPT...
when coming out of hibernation, windows apparently won't recognize modem, says there is a problem with USB device.
If I unplug and immediately re-plug modem is recognized and operates normaly. Happens every time. Bit of a pain.
4 Suggested Answers
SOURCE:
  • 944 Answers
SOURCE: Modem Driver for Windows Vista
Here is the link; http://www.nexxtech.com/nexxtech_usa.html just click on drivers on the left and then select the model from the small list for the download. Hope this helps :)
Posted on Jun 22, 2007
  • 457 Answers
SOURCE: USB Modem Model NSMODX2
why not try uninstalling the modem and then reinstall?
Posted on Sep 18, 2007
  • 137 Answers
SOURCE: i want to purchase the nexxtech usb 56k modem for
If there are even Linux drivers for this product, it is likely that they are already included with the distro and thus you do not need to download anything.
Posted on Apr 21, 2011
Nexxtech usb-to-serial doesn't seem to work with Windows 8. I'm using Hyperterminal with the connection which worked on Windows 7 but the new Windows 8 computer does not recognize the com port connection....
Every time you change an operating system or go one computer newer expect that what accessories you are familiar with cannot come with you on the journey. You have to scour the stores for newer tech to go with your newer toys.
Oct 01, 2013 | NexxTech Usb To Serial Cable
Error code 73 on a lases disc hyper beam NSM 100 cd floor model
error 73 means error in the lifting sequence check grippers
Aug 29, 2013 | NexxTech NSMODX21
I just purchased a Nexxtech Micro SD Adapter and windows xp sp3 will not recognize it at all....nothing...nada....I assume there is a driver problem with my computer usb....I am using a Logiix lgx-79041...
Welcome to Fixya. This is not a driver problem of usb because the Logiix is working fine. Are you using an external card reader or the built in card reader of your computer when connecting the Nexxtech adapter? Can you also provide the make and model of the computer. Please provide the information needed to be able to fix the issue.
Thanks
Aug 31, 2011 | Computers & Internet
I want to purchase the nexxtech usb 56k modem for linux windows vista and windows 7 my problem is my linux doesnt have a cd rom for me to use the disk is there a way i can download the drivers off the...
Mar 26, 2011 | Nexxtech 56K USB External Modem
How to set up a Nexxtech wired router?
Hi, manny_khera This could be a bit complicated...or not? First we'd need to know the make and model of your comcast modem as it may be a "modem/router" if so, it will need to be set to bride mode before your new router can work properly - to avoid "double natting" (both devices attemting to preform the same fucntion - network address translation.)
Jun 06, 2009 | NexxTech 4-Port Ethernet Broadband Router...
My computer doesn't recognize my Motorola Broadband cable modem.
Is your modem newer if so then it should have a vista driver on the cd, If not there may be a driver for it on the cable modems website. If not maybe you need a modem for windows vista.
Jan 10, 2009 | Computers & Internet
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
Driver for pctelplatinum v.90 modem
The must be a driver for that modem and OS try here: http://www.driver.com you may have to register for free to grap the driver.
Sep 22, 2007 | Computers & Internet
Sep 18, 2007 | NexxTech NSMODX2
Jun 22, 2007 | NexxTech NSMODX2
NexxTech NSMODX21 Logo
82 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
