Question about Evenflo Journey Premier Stroller
How to adjust straps on the evenflo journey clairmont carseat?
You posted this in August so I'm not sure if you figured it out yet. I was loving this system until I ran into this problem tonight especially when I couldn't find this in the manual, but I figured it out. On the back of the car seat you'll see the black thingys that keeps the straps in place, above them are these two clips that you have to push down. push down the clip and pull the black thing up , it will release from car seat and from there you're able to adjust the straps height. I already contat evenflo about not putting this info in there manaul.
Posted on Jan 10, 2009
Can not adjust harness straps on evenflow embrace car seat
Evenflo has a GREAT website section on using and installing their carseats. The manufacturer is the final authority on keeping your child safe in their seat: don't accept advice from anyone else!
http://www.evenflo.com/sme_carseats.aspx?id=321
You also ought to have your instruction manual for reference: order it for free, at this link:
https://plweb.evenflo.com/replacement_parts.aspx
Mar 24, 2010 | Evenflo Embrace
I need help ASAP to make the starps bigger
Look in the back of the carseat and you should see where you can adjust the straps and then pull the length trough the front of the carseat. I don't have an evenflo, but sometimes there's a clip you can move forward to make the straps longer.
Jul 30, 2009 | Evenflo Victory 5 Comfort Touch
I have a stroller just like Evenflo Aura Select Stroller - Somerset that one, and i was wondering how you make it so the baby can lay down...
It should have a strap with a buckle to adjust the seat into position by sliding the buckle up or down. Hope this helps.
Jul 05, 2009 | Evenflo Journey Premier Stroller
How to lower straps on evenflo infant carseat
You're trying to unattach the straps from the wrong end....flip the car seat over and on the very bottom there is a little gold clip that pops out and you can push through the hole.
May 19, 2009 | Evenflo Embrace
Trying to adjust the child seatbelt harness higher in the carseat
I located my instruction manual for this carseat. It instructed me to turn the carseat over & located on the bottom are two metal brackets that lock the seatbelt harness. You just have to detach each metal bracket & pull through the bottom slots of the carseat, readjust each seatbelt to whatever level is necessary & push back through the bottom of the seat to lock securely. Thanks anyway for your help!
Apr 09, 2009 | Evenflo Baby Gear
Evenflo journer
on the back of the carseat the are black plastic holders the straps go threw and there is a part in the middle that you push down and you pull the front staps to loosen or the back straps to tighten
Feb 17, 2008 | Evenflo Journey Premier Stroller
Carseat straps
You can move it by pushing down on the flexible tab part of the seat base just above the box, but you don't need to move it at all in order to adjust the straps.
In order to move the straps I remove the clip side (the opposite side of the box), this removes in the same manner as the black box side, you just push down onthe flexible tab on the base; and run it through backwards, slide it into the next hole up, to make it larger run it back through the holes and click it back into the base in the back of the seat. This can all be done without disabling, The clip in the front of the seat must be unfastened but it will all fit through the holes in the seat to adjust the straps.
Oct 04, 2007 | Evenflo Embrace - Rainforest
Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Jul 31, 2007 | Evenflo Embrace - Rainforest
Car seat straps
ON THE BACK OF YOUR CARSEAT ARE 2 METAL LATCHES ON EACH SIDE. REMOVE ONE BE PUTING THE STRAP THROUGH AND ADJUSTING IT TO YOUR CHILDS FIT.YOU COULD ALSO PUT IT THROUGH A SECONDARY HOLE IF YOUR CARSEAT HAS ONE TO PROPERLY HOLD YOUR CHILD SAFELY.LET ME KNOW IF I WAS ANY HELP...
Jun 03, 2007 | Evenflo Chase Comfort Touch
Evenflo Journey Premier Stroller Logo
143 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
