Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Dishwasher D60355 built in,
How do you remove the drawer?
  • 125 Answers
Open the drawer, on each side of the drawer behind the front panel on the bottom there is a plastic pin, use a pliers to pull it out, (approx 1 1/2 inces long). when they are pulled the fron panel can be pulled down and then out, bottom comes out first. unhook ground wire. now you can push the tab in on the bottm front corner of each side panel, with tabs in the drawer will pull out of the track, lift the drawer and push the tracks all the way in and set the drawer off the the left side of the dishdrawer. hope this helps.
Posted on Aug 19, 2008
How to remove the upper rack on kitchenaid dishwasher
The upper rack has a captive washer with a lug that stops the top drawer from falling out. Use a torch, identify the captive washer that is connected to the rear wheel on each side if the drawer, remove these and the draw will come out
Jul 15, 2014 | KitchenAid 24 in. KUDP01FL Built-in...
How do I remove the bottom drawer to level the dishwasher
Instructions on removing drawers can be downloaded from this site. See page 7. Hope this helps.
Nov 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
What does an F1 erroor message mean. I have a
F1 means "flood. there is a flood sensor underneath the drawer, and if there is any water under the drawer the control will show that error. Check the drain hose linkage for cracks. Remove drawer and dry the area underneath.
Jul 14, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
How do I remove the bottom drawer of my F & P double drawer dishwasher for mounting into the cabinetry?
I am assuming you have an integrated double drawer unit DD603I.
The instructions for removal and refit of the drawers is available in the Installation Manual. I am able to locate one on the following site
http://www.fisherpaykel.com/admin/pdfs/pdf_installations/526607O_DD_Install_USw.pdf
You may also need instructions to prepare and fit the front panel of the cabinetry to the drawers which you can down load from
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Hope this is what you are after.
Nov 18, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The flood switch has been activated on my dishwasher
Remove the bottom drawer by pressing in the tabs on either side of the drawer (bottom edge towards the front).
Dry out the compartment with towels and let air dry.
Apr 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dishwasher not draining well
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Comment posted on Feb 07, 2009 there should be tabs on the sides of the drawers at the sliders near the front of the machine.
Feb 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher&Paykel Dishwasher DD603- How to remove drawer
on the sides of the drawer there are pins use a neddlenose pliers to pull them stright out then the drawer wil be released from the rails you will need to prees on the tabs at the sides to pull out you cant take it completely out due to the hoses attch.
May 12, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
DD603I
there is a round pin on wither side of drawer front, when ithe drawer is opened, witha pair of needle nose pliers grab and remove both of them, the drawer front then will slide down and away.
Mar 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
110 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
