Question about Brother MFC 240C All-In-One InkJet Printer
Priting with the brother
How do I get the MFC 240C Brother to print more than one page at a time
  • taznjo Aug 09, 2008
    Problem is I do choose more than one copy to print, yet it will only print one page, no matter what I choose.
Well when you want to print more than one page push CTRL+P
then if u got more than one printer installed choose your printer in the top well to print more than one i think in the bottom it says number of copies then choose how many then print.
Posted on Aug 09, 2008
How do I scan a printed page into my computor and convert it into a word doc
I am a Brother employee working for the software technical support department.
We have a solution for your issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000000431
Description of Problem 100000000379 How do I use the Optical Character Recognition software? (OCR, Word Processor)
Brother Software Technical Support
Frequently Asked Questions
Jun 28, 2014 | Brother Multi-Function Center MFC-240C...
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Not printing
First disconnect the printer from the computer, next turn off the printer off and then while holding the on button down turn the printer back on this should print a test page. If the printer ink is goo you might have to replace the print head of the printer.
http://www.retrevo.com/support/Brother-MFC-240C-Multifunction-Printers-manual/id/1071ag216/t/2/
Oct 19, 2013 | Brother Multi-Function Center MFC-240C...
How can I set my MFC-240C printer to print from my computer
switch on the printer
1. install driver for mfc-240c
2. go to control panel in your computer
step to control panel
select START then control panel
3. select printer mfc-240c right click on it and then click on click on <Set as Default Printer>
4. right click again on it the select <properties> then select "print test page"
test page will printout on printer
5. now you can use mfc-240c as printer
Aug 19, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Printer unable 4F-what does this mean?
If still under warranty, I would call Brother for an RMA (return merchandise authorization) code and return the product. Why fiddle with it?
Jan 15, 2010 | Brother Multi-Function Center MFC-240C...
Black ink in brother 240c printer does not print new cartridge
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC Shows Offline
If you go to this page on the Brother site:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc240c_all
you can view all of the available downloads for the MFC-240C. (Just select your operating system and language.)
Dec 09, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
61 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
