Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
52" rca projection screen tv
When I power on the button it stays on for a few seconds, blinks and then turns off. Is it the flyback transformer?
  • RCA Master
  • 8,617 Answers
If the light blinks 3 times its most likely the flyback. Your model uses flyback 259296 and you can get a replacement at the following link and they have free online instant messageing with a tech when you replace the flyback so they can take you step by step while you change it. Hers the link its flyback 259296.
http://servicemanuals.vstore.ca/
Posted on Aug 10, 2008
My tv wont stay on it keeps blinking on and off my 52 inch rca
I would try resoldering the flyback transformer. Often cracked solder on the flyback will cause that same symptom.
Nov 09, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca 52 in projection t.v has problems powering up
Push and hold power button. If it cycles and blinks on/off in 3s or 9 times, it is a power problem. Replace the deflection board. Cost about 250.00
Jan 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA tv will not stay on
Sounds like the flyback very famous for that model. You need Flyback 270125 you can get the new RCA flyback at the following link and they provide step by step detailed indtructions on how to do the repair. Heres the link to your flyback.
http://servicemanuals.vstore.ca/product_info.php/pName/270125/cName/flybacks
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Tv won't stay on
The first thing I would do is to check the solder connections on the flyback transformer. This is a common problem with this set
Dec 05, 2008 | RCA HD52W59 HDTV Projection Television
Rca tv won't power on
it may need a Flyback Transformer or a burnt capasitor and resistors. there are many posts with this same problem. Some a little different. Check the fuse just inside where the power supply cord goes in . if the fuse is blown you will have to find the reason it burned . But maybe you will be lucky and replace the fuse. And it will turn on. but I think that only a TV technician can fix the problem.I have a background on TV repair and I think it's the Flyback transformer. sometimes you canresolder them and they stay.
Nov 23, 2008 | RCA P52926 52" Rear Projection Television
Could I possibly have a bad flyback transformer
I would try resoldering the flyback connections on the Circuit board. if the flyback was defective it would operate and you usually get 3 blinks on the LED indicator. Sounds more like a solder issue.
Jun 15, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w15
Possible short and safety is keeping the set from burning up. A service man should be able to find the short hopefully in a small amount of time.
Nov 05, 2007 | RCA D52W15 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
184 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
