SOURCE: Printer will not print
1. Printing from one computer directly to the printer requires a crossover cable. The reason they are telling you to use a router is so you can use a standard wired cable. You can print direct to the printer from the ethernet port via a crossover cable.
2. On the settings. First, go into the nework settings and turn OFF the auto dhcp. What it is most likely doing it switching the IP address on you. Set that to manual or static, then enter the appropriate IP address.
Set that IP address in the driver under the port configuration.
So in order, can the router unless you are going to run your network through it also. And use a crossover cable to run directly from the conputer to the printer. Then turn off the AUTO on the IP address settings and make the IP address static.
Then print out a configuration page to confirm the IP settings then set the printer up from there.
The crossover cable for direct computer to printer is te key.
Any other questions ask away.
SOURCE: WorkCentre C2424 Scanning Mac OS X.
Well I haven't necessarily scanned often, but i do know if you open up a program such as word, Excel, PowerPoint, Photoshop, Corel, etc... You are given an option to scan. That way you can scan information, images and such to that program in which you use. C2424 wont give you any support because its a primary printer but the drivers should include drivers for the scanner and the computer to interconnect. If you have any photo like software on your mac. Try looking at the options at your top menu for an option or "import"
Many times it will give you the option to scan from a device.
To scan to computer its software based. Also on the Panel on the printer you should be given an option to scan. If printer is connected by USB it will be easier to detect scans from panel, but if your printer is connected via Ethernet it will be different.
I hope this helps. Try using a program that you can use to edit pictures or display. You should be given an option.
I hope this helps. Let me know what you do? and possibly i can mirror what you do on my own mac
SOURCE: Xerox Phaser 7300DN will not collate
Try using the PCL driver from the Xerox website, rather than the Postscript one supplied with the printer.
I had the same problem and installing the PCL driver solved it.
SOURCE: Xerox DCCS50 to DC12, change Cobra with X12 fiery
at the end of setting up network settings it should ask if you want to save settings, click yes then its enabled. i have never had a fiery that doesnt hold its settings so its probably something you arent pressing.
there is an issue with one of the mac OS's that it just doesnt like the old fiery rips and you will never be able to print, but i'm not that clued up on the mac side and cant remember, sorry.
from your add printer section it should automatically see the x12 and give you the options of a hold,print and direct queue. I f you havent got a pc then the only queues that is useful to you is direct. Print holds the job on the hard drive and will eventually fill the server
