Question about Zanussi Z57 / 3 Bottom Freezer Refrigerator
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
Please help, I love this older model fridge as it is large and hope to fix it. The freezer seems to work allthough there is some frost buldup on the back. the fridge part no matter what is barely cool. Can this be a part I can go get and fix? the compressor sounds fine, the fans work, do you have any advice?
  • 23 Answers
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Posted on Aug 10, 2009
Fridge part of fridge freezer stopped working
Please add the make and model of your fridge. Is it frost free or not?
Jan 06, 2014 | Beko Refrigerators
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
Kenmore elite frost free is frosting over
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
The fridge and freezer seem to be running cold - what number should the fridge be set at? And how/where do you contrrol temperature for the freezer? There is frost built up in the freezer and a bit in the...
Each refrigerator is different so a make and model would help in answering your questions!
Normally the middle position is 5 is normal, but that depends on the environment that the unit is in. Usually, there are two dials in the refrigerator section - one controls the temperature in the freezer and the other in the refrigerator.
Most refrigerators that are less than ten years old are frost free, so if your unit is a frost free unit you would need to troubleshoot the defrost circuit (defrost heater, defrost thermostat or defrost timer). But if it is an older refrigerator, then you will need to take all the food out of the unit and then unplug the unit and leave for 8-12 hours with the doors left open.
Manuals depend on a make and model. And if it is an older unit, you will probably have to buy a manual from one of the on-line kitchen appliance manual places.
Aug 05, 2011 | Refrigerators
I have a top mount frost proof 18.2 cu ft Frigidaire (P/N 241691317)and have issues with the freezer. It blows cool air but not enough to freeze food. I do see some ice build up inside the fridge and on...
Sorry to read about your problem, I hope this helps you out.
if you have a lite frost build up and not large amounts of ice, on your freezer coils, you may have low freon, in your unit..if you have the large amount of Ice, you may have a defrost issue.
The only thing you can do, to help correct the problems. is clean all outside coils, below or on the back of the fridge. vacuum and compressed air to clean them. and see if that helps the issue.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top...
Zanussi Z57 / 3 Bottom Freezer Refrigerator Logo
383 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
