Question about JBL Northridge E 250P Subwoofer
Jbl E 250P subwoofer
Light stays red does not change to green when recieving signal.sub doesn't come on.
  • ramesh911 Nov 20, 2008
    my JBL sub when switched on stays in red does not turn to green... what could be the problem.. its just 1month old sub... and I hardly used for 4-5 days only...
5 Suggested Answers
SOURCE: jbl PB12 powered sub woofer problem
These subs have had many problems, all associated with the amplifier section. PB 12's with an "M" as part of the ser. no. were assembled in Mexico and these are the ones with the amp problems. JBL fixed mine and sent it back no charge, BUT it cost me nearly $100 to send it to them in the first place. I have another one that has had no problems at all. Try sending it back for repair. At best you'll get a rebuilt unit back, at worst a substantial discount from the company for a new sub.
Posted on Aug 09, 2007
SOURCE: jbl subwoofer PB12
I had the same problem...replaced the C42 capacitor with one that I got from RS...fixed everything and all is well again. I only have moderate soldering skills, too, so if I can do it, so can you
Posted on Dec 01, 2008
SOURCE: No Sound from my JBL SCS135 Subwoofer
no sound
Posted on Aug 26, 2009
budmrtn
  • 11361 Answers
SOURCE: JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
Posted on Nov 10, 2009
SOURCE: My JBL Venue Sub 10 light stays red, will not
i have the same problem. don't as yet have a solution
Posted on Apr 17, 2010
JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
Oct 18, 2012 | JBL PB12 Subwoofer
Describe your Venue SUB10 Subwoofer Problem: The subwoofer won't turn on at all. The red light doesn't even come on. Could it be the fuse in the subwoofer? If so, where is the fuse located?
You can remove the screw near the volume knob and the screw near the on/off switch - then slide out the amp remove the black and white wire - then check the fuse - if its blown look for we repair amps - ebay - if its good then it probably still needs work - it should turn red when plugged in and no signal and green when signal is present - which means amp is on.
Sep 11, 2011 | JBL Venue SUB10 Subwoofer
Light stays red, will not switch to green. I hear no sound from the subwoofer
Red Light Constant On - Means the Amp Is Not Turning On - Signal Problem or Most Likely Burnt / Non Working Components - There Is A Guy On Ebay Who Repairs these amps.
Jun 19, 2011 | JBL Venue SUB10 Subwoofer
Nov 10, 2009 | JBL PB10 Subwoofer
Jbl sub woofer
Has nothing to do with the signal or source - it is a failure of the turn on circuit - I repair this amp - can help if you find my add here or I am located on ebay as well. Juust do a search for We Repair JBL and find the model :)
Sep 03, 2008 | JBL Northridge E 250P Subwoofer
PB10 Loud Hum and Crackle- LED Lights mixed Red/Green
Hello, Jesse. I doubt I can help, but there is at least one SIMPLE thing you can try - with maybe a 10% chance it wil return your unit to normal: Unplug the unit for 30 seconds, then plug it back in to a DIFFERENT outlet. Oh, yes - there are NO fuses or other "reset" devices. I'm sorry I couldn't offer you more help.
Jul 25, 2007 | JBL PB10 Subwoofer
JBL Northridge E 250P Subwoofer Logo
412 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
