Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave is my solution was wrong or not really specifying what really the problem is coming..? Look at your solution you said: It is a short in touchpad , you need to replace the touchpad, to find part go to http://www.repairclinic.com/referral.asp?R=154&N=696191 .. may i know wheres that touch pad you have said can be seen on microwave? and for you to know my solution was 10mins. ahead before your solution was posted.. and i'm not doing such placeholder you are saying.
  • GE Master
  • 9,098 Answers
Very good! Gimme a FixYa!!
Posted on Aug 12, 2008
I replaced my 40 watt bulbs in the back of my microwave and they still don"t come on. What else could be wrong.
That's a problem on the board caused by a bulb blowing (or being removed) while the unit is plugged in.
A bulb filament shorts to the base, damaging the board, but it can usually be repaired affordably.
Contact me directly below for full information.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Dec 09, 2017 | In Microwave Ovens
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
Frigidare microwave has humming noise when not in use
You have a shorted cook relay.
Apr 26, 2013 | Microwave Ovens
GE microwave: model 1840 circuit breaker trips when strarting micro wave
Circuit Breakers do weaken over usage. It is not usually a time factor as much as a load factor. Each time a circuit breaker trips, it loses its ability to carry the same load as it did previously. In other words, a 15 amp breaker only carries the ability to carry 15 amps once. I recommend replacing the circuit breaker with one that has a matching rating. If you do feel up sizing is necessary, check the load rating of the appliances to make sure the additional size really is necessary. Increasing power to appliances that shouldn't need it increases the risks of potential electrical fires and masking real issues. Try changing it with higher amp breakers.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 27, 2010 | Microwave Ovens
Microwave in Jenn Air Microwave/oven combo is not heating at all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 07, 2009 | Jenn-Air M170 Microwave Oven
My Microwave is displaying F6 and running when plugged in.
I found a sheet that says to check wiring to main or microwave relay for shorts. If no shorts found, replace control board.
Apr 10, 2009 | Whirlpool GH7145XF Microwave Oven
Panasonic microwave...
Without HV test equipment it is quite difficult to determine if it is the magnetron or inverter.
5 years is a little short for magnetron failure but it appears that this is about all you can expect these days from a magnetron - the best I have seen was 11 years. I have not seen an inverter failure as yet (although I am not a full time repair man). The main reason I suspect it is the magnetron is the short time period from start to stop - it is typical of magnetron failure in Panasonic microwaves.
As regards door hinge side, that is one of the great unknowns. I suspect it comes from most people being right handed but even refrigerators could be specified as right/left hand hinged originally and now can be changed by customers.
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
Outlet wired wrong
It should still function fine, but it will not be safe since it will probably not blow the breaker in the event of a broken "hot" wire or other short inside the unit.
Are you having trouble with your microwave now?
We're happy to help if you do.
Please reply back here if you still need help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 08, 2008 | Maytag MMV4205 Microwave Oven
Waveguide cover for Kenmore microwave
Try replacing the screws with larger ones. Maybe you ordered the wrong piece, if your microwave comes with a mica cover (A fine, square piece of mica) and you received a plastic one, you will need to get the right piece or adapt the one you received.
You can get the mica cover on any microwave service.
Feb 16, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
88 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
