Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
LG LDS5811BB Dishwasher
The dishwasher suddenly stopped working. I pressed power button and nothing happened. No lights, no power. I have check the black and white wire behind panel in front and the power cord is good.
  • Mabelworld Nov 01, 2008
    Have the same dishwasher, worked fine for the first 12 months, on month 13, suddenly stopped working. No power, no lights,nothing. Than for no apparent reason, maybe a day or so later, it will suddenly turn on and go through a cycle. What gives?
  • 423 Answers
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
Posted on Apr 10, 2009
LDS5811BB LG dishwasher IE code. What does this mean?
WATER INLET ERROR Water has not reached to the pre-set level within 8 min. since inlet valve operated, or water has not reached to the normal level within 25 min. stop cock turned off, faulty inlet valve.
Sep 19, 2014 | LG Dishwashers
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Jan 16, 2010 | LG Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Door hinge adjustment to LG Dishwasher
There is no adjustment to the door hinges. If your hinges are failing they will need to be replaced.
Jan 06, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to miss_vmari@netzero.net. I would like to solve my dishwasher problems as soon as possible. Thank you!
Dec 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kitchenaid Dishwasher KUDS24SEWH?
This problem was aparently classified under the LG dishwasher / LDF6810ST section, I don't think this problem got looked at by KitchenAid gurus.
Were the problems resolved?
Sep 24, 2008 | LG LDF6810ST Stainless Steel Built-in...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
1,284 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
