Question about Sharp UX B700 Plain Paper Inkjet Fax
Receiving a fax from a certain number
I can receive and send faxes numbers all over however, this one phone number in my own area code cannot send to me. I hear the fax ring and then they tell me it tells them that my machine is busy. My machine doesn't even say anything and it doesn't ring more than one small chirp. HELP!! Thank you
  • 2,120 Answers
Does the other party have a DSL phone line?
Posted on Sep 01, 2008
We are having issues faxing to one particular number. We think our fax goes through, but spits out a Error 345*. Nothing is sent
fax machines talk to each other before sending data to ensure that the sender/receiver are on the same format and are compatible
for one particular number to be a problem indicates a fax number problem in setting the dialed number area code , dashes etc are all specific
ring the receiving department and ask to confirm that they are having trouble receiving faxes from your number as well
Dec 14, 2016 | HP Office Equipment & Supplies
My fax machine MX532 won't let me send a fax though the machine
This is probably an issue for the receiving fax. Try this:
1. Find a piece of paper and write fairly large:
Call me if you get this
Your name
Your phone number
2. Send this to a different fax machine at a different company and location. If it works, then attempt to send it to the same fax you initially attempted.
- If it works then your document may be too large and you will have to send it over a couple pages (or less at a time).
- If it doesn't work then there is a compatibility issue with either your or the receiving end fax machine. You will have to find an alternative fax number to a different model fax machine. Don't expect the company on the other end to just change out their fax machine but they may have another model at a different phone number.
Another alternative - you can attempt to scan your documents and send them by email but check with your and the receiving destination security departments.
Best wishes,
Aug 25, 2016 | Canon PIXMA MX532 Wireless All-in-One...
Able to send and receive faxes. some numbers
It does not sound as if there is a problem with your machine. The receiving parties may have given you the wrong number to send to.
Call those numbers from a regular phone and listen for fax tones.
Aug 19, 2009 | Minolta bizhub 180 Black and White Copier
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Receiving fax
Hook up a regular phone to the line and dial *69.
The number should also show up on the display if the other party has programmed it in the sending fax.
Feb 16, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Won't send faxes to 817 area code, all others OK
The recipient may have a DSL phone line, or receiving to a fax server that blocks your area code.
Oct 14, 2008 | HP 640 Inkjet Fax Machine
Fax will not send
Does the receiving or sending party have a DSL phone line?
Aug 01, 2008 | Brother MFC-8220 Fax
Problem receiving fax from outside source . phone rings acknowledges receive on screen but no fax comes through. other source sends faxes to other sources no problem & i receive faxes from other...
In the last statement you said you RX faxes from other sources? which means you can't RX from one or a certain source??
1- could be area code
2-could be your memory is almost full and their faxes are too long
Jul 31, 2008 | Samsung Office Equipment & Supplies
Receiving a fax
Faxes fail intermittently or with only one fax number
  • If static is present on the phone line, fax communication may fail. Have the phone line checked and serviced by the telephone company (or have the other party check their line). Phone line quality is the most common reason for intermittent fax failures. Some older locations and buildings have inadequate phone system wiring.
  • If you are trying to send a color fax and it fails, try sending the same machine a black and white fax. Normally the fax will detect that the other fax is not color capable and will offer you the option to send the fax as black and white but this might not always be the case. Do not send color faxes unless you know the other fax machine is capable of receiving color faxes.
  • Check the phone cable from the wall jack to the fax. It should not be coiled or longer than necessary. Coiling the cable can cause cross talk or echo on the line. Signal strength and quality can be lost with long cables.
  • Make sure the phone cable routing (and any cables not plugged into the same jack but sharing the same line) is not near any electrical appliances (electric motors, fans, kitchen appliances, or televisions). Many of these devices do not have sufficient electrical shielding and can induce electro-magnetic force (EMF) onto the phone line. Computers are usually shielded sufficiently and do not cause this problem.
  • Do not use a call-waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
  • You can block certain faxes on some models. Verify that the telephone number of the sending fax is not blocked in the faxing software. This is usually located in the Fax History.
Nov 08, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Intermittent problem of faxes not being rec'd from various areas
After a detailed discussion on chat, we got disconnected before accepting payment. This is not a problem with your fax, as it seems to be receiving most calls fine. I suggest printing out a report - Menu/Set, 2, 0, 2 - of caller ID history and having the phone company look into it further. Either there is a problem with your phone line, or someone is prank calling your fax from outside of your caller ID service area. Both are problems for the phone company to fix.
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Sharp UX B700 Plain Paper Inkjet Fax Logo
135 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
