Question about Canon PIXMA MP780 All-In-One InkJet Printer
Error: Wrong Cartridge
Copier/fax will not work at all - I've replaced ink cartridges. Can only fax outbound. Cannon MP780 printer posts a wrong cartridge message. Will not print, copy, etc. Turned on and off, replaced cartridges, tried to re-calibrate heads. Please Advise?
  • jazper6 Aug 10, 2008
    I have the same problem. Any suggestions?
  • Anonymous Aug 11, 2008
    Mine started this this morning
  • 96 Answers
Yup I had the same problem and there is only 1 valid solution. Change the print HEAD. its a removeable item that is easily replaced. all you need to do is remove the ink cartridges (All) and flip up the lever where the cartridges are . This will allow for the removal/replacement of the head assembly. You can alays try cleaning this head assy with (Ammonia D) just in case you are one of the lucky one just to have a defective connection. Note: Worked for me and everyone else I ever saw with this error. (I bought my head on ebay)
Posted on Jun 09, 2009
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Canon Wrong Cartridge
May i know if you use an original ink for your printer..?
May 30, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Re: wrong cartridge error message I believe it has to do with the page source selection rather than the ink cartridges. I am trying to change the page source on my MP780 and am unable to. Any ideas?
Had similar prob with my brother copier not accepting generic cartridges. We finally fooled the machine by unplugging it for a bit to let everything reset to default settings. Software then assumed everything was already in order and worked fine. Hope this helps.
Nov 23, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error: ''Wrong Cartridge'' when no new cartridge has been installed
It is probably one of the cartridges. Usually, when the message "wrong cartridge" appears, the cartridge is faulty.
Apr 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
Here is what I did and it now works just fine.I turned off the printer and unplugged the power cord, and unplugged it from my computer. I then removed all the ink cartriges and removed the print Head I got some rubbing alcohol put it on some toilet paper and wiped down the back and bottom of the print head.Plugged everything back in and It now works better then ever.
Feb 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Wrong Cartridge Error Message
The Print Head might be the fault of that,try replacing the print head and see if that helps
Jan 31, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
123 people viewed this question
old marine
old marine
