Question about LG Dishwashers
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
  • 6,487 Answers
Try first to plug the dishwasher on a different power outlet just to check that this is not a problem with the power outlet where its plug in if still no power this can be a problem with the power cord or the power supply unit of this dishwasher and needs a replacement...
Hope that helps.........
Posted on Aug 09, 2008
    Genius:
  • 1,665 Answers
Check fuse of your home power outlet .It may be dropped if automatic or blown.
  • LG Master
  • 19,396 Answers
There is a fuse on power unit, that should be tested first, check also a different outlet.
  • Ginko
    Ginko Aug 10, 2008
    Here is service manual for a similar model, usually the fuse should be on pcb behind power button. Remove also base cover and harness and hose assembly and check wiring connections (pg 21).
  • Ginko
    Ginko Aug 10, 2008
    You need to test the fuse for continuity using a multimeter tester, if
    the multimeter returns infinite impedance then fuse is blown and must
    be replaced, the fuse is not normally glued, but after a short some
    contact may have melt down and now fuse is soldered. If this is the
    case, fuse must be unsoldered and replaced.
    See if you can publish here a photo of the fuse, this can help us to tell you how to replace it.
2 Suggested Answers
SOURCE:
  • 423 Answers
SOURCE: LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
Posted on Apr 10, 2009
LDS5811BB LG dishwasher IE code. What does this mean?
WATER INLET ERROR Water has not reached to the pre-set level within 8 min. since inlet valve operated, or water has not reached to the normal level within 25 min. stop cock turned off, faulty inlet valve.
Sep 19, 2014 | LG Dishwashers
Are there any service bulletins available for the LDS5811BB LG dishwasher?
Yes there are several bulletins for this model number and for different years.
Jul 19, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Door seals for dishwasher lds5811bb it is leaking water and all I want is a diagram of parts so that I can order the right ones. I need the tub seal and the door seal.
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 19, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Jan 16, 2010 | LG Dishwashers
Drying cycle vents at bottom of door causing a slip hazard
call the manfacturer and give them give them make model and year of machine.If problem they may be aware of it and should be able to help you
Dec 16, 2009 | LG 24 in. LDF 7811 Stainless Steel...
I have an LG Diswasher LDS5811BB Bought in 2006
LE is a motor error The Motor is working abnormally.
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Aug 29, 2009 | LG Dishwashers
LG dishwasher won't dry
Recommend you confirm that the rinse aid is not empty.
If problem persists and you are not getting an error message, contact LG service and pres them for the retrofit they released for the LDS5811 (and other models) that dramaticly enhances the drying ability. Until it is replaced, be careful because it is possible tht water will leak from the door panel (not directly from inside the diswasher, but through the door panel-based drying system.
Press them for a no charge repair for this problem and be persistant, firm but polite. If the agent is not helpful on their own, request to be "escalated" to his/her manager. Good Luck! and report back what you find. Thanks!
Mar 29, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Door hinge adjustment to LG Dishwasher
There is no adjustment to the door hinges. If your hinges are failing they will need to be replaced.
Jan 06, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Good Luck!
Aug 09, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Era codes
The PF code means that there is a power problem with your unit. Make sure that you're not having issues with your outlet.  Check the connection at the junction box to make sure they're good and tight.  If both of those check out ok, open the front panel of the dishwasher and check the wiring harness there.  About 1/3 of the way up from the bottom of the door, inspect the wire harness for any signs of cracks or breaks in the wire.  Repair the damaged wires and that should take care of your PF issues.
Jun 24, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
786 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
