I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
thanks for your help! I'll look at the solutions [:
