Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Lamp Light Where can find a lamp light and at what cost?
  • 927 Answers
Good Day, vincetgsmit;
To locate you call local Service Center or call HIT at
1-800-448-2244, the cost is about $225.00 depends where you buy it. Good Luck, big IRISH.
Posted on Sep 06, 2008
Tip
If after replacing the lamp it did not light up.
Hi,Sometimes after replacing the lamp on their DLP or LCD people still keep getting the red lamp indicator or simply it doesn't light up.Most of the time people forget to close the door cover of the lamp area.There's a switch that's pressed when the door is full shut,if it's not pressed it will not let the tv light up for safety reasons.Another reason why it doesn't light up or keep getting the lamp indicator is because it needs to be reset it,for most tv's what works is to unplug it wait 5 min and plug it back again.For some Mitsubishi models they have a reset button you can press and that will do the work.Other brands have reset procedures like holding the menu button while pressing volume button etc.After you've done this and still doesn't light up you might be experimenting the most common failures like the ballast which is the board that powers the lamp.When the ballast is to weak to power the lamp it might light it up for some minutes and then will shut it off.The procedure and cost to replace it is easy and low in repair cost.This is something you can do your self,most instructions are on youtube.
on Mar 23, 2010 | Audio Players & Recorders
Lamp light blinking
The problem is that your lamp has expired, You need to either get in touch with the brands authorised repair agent and they can order and replace lamp( at a cost) or you can replace the lamp yourself. Also make sure you know how to rest the lamp use hours after replacing the lamp. Good luck.
Nov 20, 2009 | Toshiba 62HM196 62" SD Television
RED LIGHT ON LAMP INDICATOR , TV IS NOT WORKING cost for the lamp ?
Depend, buy the brand name light or generic lamp.Brand name $100 to $150.
Oct 31, 2009 | Zenith E44W46LCD 44" Rear Projection...
My M6750 notebook monitor will not light up(it's
The fault could be a faulty inverter or a faulty CCFL lamp.
The inverter supplies high voltage to the CCFL lamp anf the CCFL lamp is a tint fluro lamp and it dims with age or fails like any fluro lamp.
You could test the voltage output of the inverter with a multi-meter or just replace it cost about $40 and the CCFL lamp cost about $10.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 28, 2009 | Gateway M-6750 Notebook
Temp light and lamp light are blinking. TV is picture is black
Sounds like a 50v500 with a bad light engine, first check the lamp , pull the front cover off remove the lamp door screw , two screws hold the lamp in, see if the lamp is popped. if its good, the light engine is bad cost about $500-$800
hope this helps
Eric
Aug 20, 2009 | Hitachi Televison & Video
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
New lamp still blinking red light
I phoned Olevia and the Tech support said that if the Red light Flashes 3 times and the Green light flashes once and then this process is repeated - it means the Lamp is no good.
Tech Guy also said that this TV should never be placed near a Window/door - no sunlight!
My TV is doing the same thing and I need to get a lamp - they want $110 for the lamp.
Where did you buy the lamp from? How much did it cost?
Aug 31, 2008 | Syntax Olevia 50" Rear Projection...
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
47 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
