Question about HP Compaq Presario V6000T Notebook
COMPAQ screen fails to light up
But lights on and computer obviously connected. what could be wrong?
  • czcarlin Aug 12, 2008
    Thank you for your advice which was thorough and clearly stated but since the simple solutions did not work, the computer will be taken to a service center... czc
    Scholar:
  • 53 Answers
Here issue is not clear, like if the issue is
1. There is no display on the notebook even though power LEDs are glowing?
2. There is display but very dimm/dark to see the display?
I will explain both the senarious, if the issue is something diff other than the above mentioned two, then you should get back to us by elaborating on the issue.
Solutions:
Sol: If this is the case, then try power drain:
Try doing power drain by taking out the battery & keep holding down the power button for complete one minute to drain out the power from the computer components. Restart the computer after putting the battery in.
Try restarting the computer only with the AC power, without the battery & vice-versa.
If the issue persists, then the issue would be with the motherboard components, you need to contact service center
sol: If this is the case, then connect the external monitor to the notebook andcheck for the issue.
If the display is fine on the external monitor, and if you can see the display on the notebook screen by using the flashlight, then the issue will be with the back light of the notebook screen. Here also you have to contact service center.
Please reply if you need any further information on this issue.
Posted on Aug 09, 2008
My hp compaq nc600 laptop wont turn on just an ornage light comes on, black screen and fan for 10 seconds then dies?
In the first instance you need to check your power lead. Exchange it for another one that you know works.
Apr 09, 2013 | HP Compaq nc6000 Notebook
My HP Compaq nc8000 will not start up correctly. When i hit the power button, only one green LED comes for a few seconds, then a yellow LED (which is the charge light) it sounds like the laptop is powering...
Check it is powering laptop,if not the jack has bad connection and not connecting to mainboard constantly,
Dobt thats what is happening in your case but need to rule it out for next step.
Remove the battery then try ac adaptor on its own.
Next try removing ram,insert one stick only,next sub it with other stick only,if still no good remove hard drive,you are attempting to get bios start screen to show up,if still no good you may be looking at mainboard power regulator ic fails,which are a real problem on some compaq models this also damages other components on the mainboard(google search will reveal what im on about)
Dont remember offhand but if its the type that has common mainboard fail its not worth repairing as the new boards always fail eventually due to same problem.
There are also light error codes in the back of the manual and available online to diagnose this by the type of lights showing up.
Feb 17, 2011 | HP Compaq Business nc8000 Notebook
Hello. I got given a compaq presario 700
motherboard is not alright. there are failing compaonents on the motherboard( capacitors, resistors e.tc). however, try to go to bios and stay there for some time and see if the same will happen.
Regards
Feb 11, 2010 | Compaq Computers & Internet
My Compaq CQ50-110 will not boot-up. The lights turn on, but the screen remains black and none of the start-up sounds begin. I have removed the hard drive and it works, power adapter is good, RAM was...
Look at the screen at a shallow angle and look for any 'ghosts;' images that you might expect to see during boot or after.
If you can discern anything, then it could be a failed back-light (fluorescent) or the inverter for it which is customarily on a single small board that is obviously connected to the display/cover half. This is potentially user replaceable with care and a few small tools.
Jan 12, 2010 | HP Compaq Presario CQ50-110US Laptop
Compaq Presario V2000 laptop stuck in hibernate or sleep mode. Power light, battery charge light and HD lights are all on, nothing on screen, no working sound of HD. I have unplugged/plugged, taken the...
Try booting into the BIOS Screen and resetting to factory defaults. If that fails suggest swapping the hard drive out and re-install the Operating System - Save your old data and migrate the data off the old drive. You can buy an external drive adapter to connect the harddrive to a USB port to migrate you data.
Good Luck!
Sep 09, 2009 | Compaq Presario 1275 Notebook
Compaq M2000 laptop lighting bolt flash 3 times wont start
Could be a bad mother board or a hard drive..see if you can connect the hard drive with a USB on another machine and run a test on it...
May 27, 2009 | Compaq Presario M2000 Notebook
Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Jan 20, 2009 | Compaq Presario 2190US Notebook
Hp V2000
This is generally caused by a bad inverter. However, this can also be caused by a loose connection. Check all the screen connections, screen, screen to inverter, and screen to motherboard. If the connections are good, then the inverter is going out.
Aug 06, 2008 | HP Compaq Presario V2000 Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Black screen```
You cant fix it Im afraid I think the screen maybe poked and died on you. To prove a point plug and external Monitor to the laptop and if all is well then Im afraid the latter I have informed you is correct. There are quite a few models of laptops out that nfortunately are built to fail so the rotten companies who make them sell another. To replace your black screen if it is damaged would be $700 and thats for the screen there is the fitting yet you might have pay the man for that and they are not cheap. I wish I could help you further or wave a wand but I cant Im sorry.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V6000T Notebook Logo
292 people viewed this question
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
