Question about Peavey 32fx USB 32 Channel Mixer
PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
The right main fader is very crackly. There are quite a few (a dozen?) points where the sound cuts out very briefly but completely. If you leave the fader still, the rest seems to work fine, but adjusting the volume while the band or a CD was playing would sound rubbish on the left. I slid the fader up and down for a couple of minutes to see if there was dirt on the slider that would shift; no improvement.
  • Anonymous Dec 14, 2008
    problem from the start - looking for a parts source
    Problem Solver:
  • 17 Answers
Its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Posted on Feb 02, 2009
SOURCE:
I have been given a peavey pv8 mixer without the power supply, I have used a different power supply with the same voltage, my problem is when it's turned on the clip lights are glowing on all channels and...
Kinda hard to tell you exactly what the problem is. Your current power supply may not be able to give you the amperage you need even though the voltage is the same. You can get the correct power supply on Ebay.
Peavey 16 5 Volt II Power Supply 03013830 Mixer PV6 PV8 PV14 PV 6 8 14 16...
Dec 20, 2017 | Music
Right fader knob doesn't do nothing. No sound come out from my right speaker when I turn the right knob up
PV series mixers from peavey suffer from horrible sliders pots quality, so be prepared to change that pot, it is pretty easy to change, real difficult comes out when you are trying to reach it, let me know a bit further to help you out troubleshoot accurately the issue.
Jan 18, 2013 | Peavey Pv 20 USB 20 Channel Mixing Board...
Manual for Peavey PV6 6 channel mixer
Contact Peavey toll free at 877-732-8391 or by email at [email protected],
Aug 05, 2012 | Peavey Electronics Peavey Pv6 6-channel...
I can't get any sound to go through Mackie 1604-VLZ3. I've tested to insert sound to every channels and checked all button positions and nothing comes out from main output or the phones....
There is NO way to select channels to "Source"... The selections on this mixer are to send the channels to SOLO, Sub1-2 or Sub 3-4 and/or main L-R. You should have the bottom button for each channel punched down to L-R. NEVER connect ANYTHING other than an external effects unit to the INSERT jacks!!!! These jacks are combined output/input jacks with send and return on the same jack. Special insert cables are used for these. An external drum machine should be connected to a line input for one of the channels USING a TRS balanced cable. Page 28 of your user manual shows the block diagram and signal flow diagram. The trim control is the input gain control. Start with those say at 12 o'clock and advance the fader for the channel of interest...you should get signal at the main outs. MAKE SURE that the lines from the mixer to the amps are BALANCED TRS type cables... You cannot use unbalanced cables for this. The user manual explains balanced cables and what they look like. I just repaired one of these mixers that some foolish people plugged stuff into the MAIN INSERT jacks and blew out the driver that drives the MAIN insert which kills the input to the MAIN output drivers. There is one small chip between the AMAIN fader and the sub next to it and one has to remove every knob and take the unit all apart to get to it... It is a tiny surface mounted part the size of a matchhead with 8 leads... not for the faint of heart to repair. As a test of this part, you can plug a st of headphones into the RIGHT MAIN insert jack and drive audio into a channel... turn trim control up fully for the channel and the fader on full, and set the PAN control to 12 oclock and punch down the L-R button for that channel. You should hear the audio in ONLY the left ear... Now try the phones in the LEFT INSERT jack... you again should hear the audio in the left headphone only (these jacks are not stereo like the headphones). If you cannot hear anything, then likely somebody has blown that driver in your unit... It is painful and time consuming to repair this... there are hundreds of knobs to pull off and put back on... dozens of screws and cables and to get it all back together. Also make sure ALL of your interconnected equipment is powered from a SINGLE receptacle or power module. Read your user manual thoughroughly. You can get one online download if you need it.
Sep 10, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I am unable to send a signal via aux 6 from a channel to ONLY the K sub. The only way I get signal is if I raise the channel fader but then the signal goes to the house L/R mains as well. How do I send a...
It appears that AUX6 is default factory strapped as POST FADER. If you want to change that you will have to disconnect jumper L to A for all channels you want the AUX to be pre-fader and instead connect K to S for the option jumpers. I don't know if this requires soldering or whether they are push on jumpers. These should be available in the back cover. In ADDITION you will have to run the switched pre/post fader switch in the PRE position which will make ALL AUX's that are strapped this way PRE FADER.
Jul 09, 2011 | Allen & Heath Mix Wizard Wz3 16:2...
I have purchased a peavey pv 6 (not the usb) and I have a squeal problem when I activate the tape to mix button and rising the master fader to 0 and my headphone volume. I am using a creative soundblaster...
You MUST turn off the echo from the computer OR remove the sound card to line in connections. The tape out goes through the sound card and immediately back out to the tape in and around it goes for feedback.
Jun 28, 2011 | Peavey PV6 Mixer
Faders not working properly on am844d right channell goes in out when I wiggle the main L/R fader. Some of the channel faders are eractic. The level of volume is not responding right to fader...
You probably wrecked the faders putting De-Oit in them!!! NEVER use that in pot and faders... It is for switch contacts only.
You have ONE chance to save them. From Home Depot get a can of CRC226 in the electrical dept. Put some of that using the spout into each fader near the middle and work the faders. The CRC226 costs about $2.70 a can. Make sure it is the 226 as there are OTHER CRC products there and only 226 is the one that is suitable.
The De-Oxit will have cleaned out the lube of the faders and if you are unlucky, one or more of the wipers will have folded back which is fatal... The CRC226 is an electrical lube that I have restored faders and pots with... It has many other uses including lubing plier joints...
Dec 31, 2010 | Phonic Am 844d Mixer 8 Mic/line 4 Stereo 4...
I just bought one last night. I love it so far. I really don't no how to use it. My first question is how do I connect my monitors.? My next one is how do I use a mic. I have tried with the xlr input and...
http://www.behringer.com/EN/downloads/pdf/1622FX_P0557_M_EN.pdf
there is the manual
But to actually answer some questions for you as well.
1. How do I connect it to my monitors?
Out of the back of the console there is a Main Out : Left and Right. there are two sets, one is XLR, second is 1/4 in. Run those to Powered Speakers and Voila.
Note: If you are using unpowered speakers then you will need a poweramp to run speakers.
2. and 3. first make sure your fader is all the way down
Once you plug in your microphone the top white knob is your gain preamp actually turning your voice going into the board up.
Second set your Main Mix fader: far right faders to 0. Then, the channel your microphone is on bring up the fader and you should start hearing some of your vocal through the monitors.
4th. At the Top right there are two sets of stereo ins (RCA) all you need is a 1/8 in to RCA cable coming out of the Headphone/Line Out of your computer.
Good Luck, Cody J.
Dec 16, 2010 | Behringer XENYX 2442FX Mixer
I have 2 peavey 2600 amps with 1 pv6 mixer wanting to run subs off 1 amp and sp2s off other amp but only have 1 main output on the pv6 mixer whats my solution
you can run one amp from the main out puts and the second amp from the CTRL Room out puts. The CTRL ROOM are outputs that are linked to the same bus as the master fader. This will work fine...
Best of luck
Sep 02, 2010 | Peavey Pv 2600 Power Amplifier
I have a behringer xenyx 2442 and the main output fader no longer works. Each individual channel fader now seems to go direct to the main mix and appears to bypass the main fader
The utput fader has probably been broken. If the knob takes a hit, it breaks the resistance element. The part is inexpensive but it takes a lot of work to access and replace the part.
Oct 14, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Peavey 32fx USB 32 Channel Mixer Logo
738 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
PNiss
Are you a Peavey Music Expert? Answer questions, earn points and help others
