Question about Mitsubishi WT-46805 46" Rear Projection Television
Projection bulb There are actually three tubes in this unit: blue, green, and red. They would not all have gone out at once, and that can't be the problem if I am seeing light on the screen as described in my original post.
  • linush Aug 09, 2008
    I took the back cover off and I could see all three filaments glowing when power was on. That means the tubes are good - right?
    Master:
  • 623 Answers
They are interconnected with each other...if one goes the others will follow.in my experience its always the red one that gives...
Posted on Aug 09, 2008
  • ritchie dempacco
    ritchie dempacco Aug 11, 2008
    okay..your tubes are good! then the the problem must be on the circuit board connections,no diy,s here take it to a tech
Where is the bulb located on a hd56w66 tv
If you have a HD56W66 it is not a DLP set it is a rear projection Tv set . id does not have a bulb it has three picture tubes one in red blue and green
Oct 20, 2014 | RCA Televison & Video
I need to find a bulb for a D52W26
your model doesnt have a bulb like the DLP projection. Instead you have three CRTs ( picture tubes) one red, one green and one blue. If you respond to this same post with your symptoms I can assist with diagnosis.
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
Red Color is not showing up.
THIS TV HAS KNOWN PROBLEMS WITH PICTURE TUBE FAILURES AND I WILL PREDICT THAT AT SOME TIME IN THE FUTURE EVEN IF YOU GET IT REPAIRED NOW, ONE OF THE REMAINING TUBES WILL START GIVING YOU PROBLEMS. YOU HAVE THREE TUBES IN THIS UNIT (RED,GREEN & BLUE) AND THE RED TUBE IS DEFECTIVE. SORRY FOR THE NEWS BUT JUST TRYING TO SAVE YOU THE ULTIMATE COST FOR REPAIRS, FOR A PICTURE TUBE REPLACEMENT AND SUBSEQUENT SET UP IS A MAJOR & COSTLY REPAIR.
HOPE THIS HELPS
Jul 07, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Spots on picture screen,color not correct
the picture tube has three color production units (bulbs) red, yellow and blue.....since these three colors can be combined to produce almost any color. as you have specified the red bulb might have damaged due to one of the following reasons.
1.continuous usage
2. keeping your tv in standby mode for a prolonged time.
the only thing you can do is call a technician and get your damaged part replaced.
remember please do not try to disassemble the unit yourself.
May 28, 2009 | Panasonic PT-52DL10 52" Rear Projection...
Bulb Replacement
It might be the the socket board on this model not the crt tube. Closely look at each tube these tubes end up contaminated. They start looking like lemonade inside. Usually the blue and green, with the tv off see if the green and blue are as clear as the red with a flashlight. You might want to call a service center. Cheaper in the long run over the cost of a tube.
Apr 17, 2009 | Philips 60PP9753 60" Rear Projection...
Philips Projection TV Bulbs need changing
Buy a new television. The "bulbs" are actually small picture tubes, also referred to as CRT's or guns. There are three of them, Red, Green and Blue. The cost for the tubes alone will probably exceed the original purchase price of the television. If the new tubes do not have the lens assembly attached, then you will need to transfer the old ones. This involves draining, cleaning, and refilling the coolant chambers. Once installed in the set, there is a series of mechanical and electrical adjustments required, to get the picture aligned or converged. This procedure is not recommended for the inexperienced. If cost and time are not an issue, then everything can probably be found on the Internet. Simply search the web for your model number. You will need the remainder of the model number first. There are at least eight models starting with 46PP9302. You are missing three additional characters.
Discouraged yet?
Nov 15, 2008 | Philips 46PP9302 46" Rear Projection...
When tv is on it just loses all color but blue
the tubes are going out on you,probably time to replace them
Oct 27, 2008 | Sony KP-51WS500 51" Rear Projection...
JVC TV
On projection TV's there are three tubes red,blue and green. It sounds like the green driver transistor is open. Check for loose connections or cold solder joints on the crt board at the back of the green tube.
Apr 07, 2008 | JVC AV32F476 32" TV
KP-51HW-40 FLASES BLUE ,RED, GREEN
Your picture tubes are trying to short out you have 3 red, green ,blue.
Mar 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
