Question about Compaq Computers & Internet
My Compaq Evo N400c,the mouse keeps going in differt directions and i need help on how to fix it?
  • Compaq Master
  • 3,051 Answers
Turn over the mouse and see if the is a cover around the ball and turn it counterclockwise this will release the ball dont lose the ball ok now look at the rollers and see if they are really dirty use a stiff object or even a toothbrush works well to get the lint off of the rollers make sure you clean all of them then put the ball back and put the cover back on and try it it swhould be better now good luck !!!!
Posted on Aug 09, 2008
WHAT DO I DO TO MY COMPAQ EVO N400C TO GET IT TO RECOGNIZE A REPLACEMENT MONITOR
It should have no problem ,,connect vga to vag out the back,,of evo,,should work,,also the compaq website is very helpful,,support and driver downloads for everymodel,,goodluck
Nov 19, 2010 | Compaq Evo N400C Notebook
I canot clear setup password cmos on laptop compaq evo n400c
compaq website,,driver downloads and support,,,,they will have a answer for u
Nov 03, 2010 | Compaq Evo Notebook N400c
I need an instruction manual for HP/Compaq Evo N400c
hello there:
yes the manual can be downloaded the manufactures website ie www.hewittpackard.com just make sure that you find the right manual for your model
Jul 29, 2009 | HP Compaq Evo Notebook N400c
Cannot restart services error 1068
To resolve the problem, fix the dependency information for the Spooler service.
Click Start, Run and type the following:
CMD /K SC CONFIG SPOOLER DEPEND= RPCSS
Alternately, to accomplish this using Registry Editor: Click Start, Run and type Regedit.exe
Navigate to the following branch
HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Services \ Spooler
In the right-pane, double-click the DependOnService value
Delete the existing data, and then type RPCSS
Close Regedit.exe
And workstation is only needed if you are on a network.
May 11, 2009 | HP Compaq Evo n400c Notebook
Upgrading memory on my Compaq Evo N400C notepad
i have the same Compaq Evo N400c its a ram under the keyboard check there to upgrade it i got Compaq Evo N400c 1gb ram
Dec 30, 2008 | Compaq Evo Notebook N400c
I have a compaq evo n400c needs a power on password key
If you forgot your password then you have to take your laptop to hp service centre. Because the laptop need to be disassembled before one can reset the poweron password.
Nov 23, 2008 | Compaq Evo Notebook N400c
Evo N400c Mouse cannot move where I want him to
We had the same problem and with research we found that this notebook has a history of this problem. The solution I found is to buy a USB mouse, plug it in, then go to control panel- mouse- hardware and disable the built in mouse. Then you just restart and use your USB mouse as your primary mouse. As to a solution to fixing the built in hardware, I don't think you can do that.
Sep 10, 2008 | Compaq Evo Notebook N400c
Evo n400c
Did you charge it for up to 8 hours?
Caring for your Compaq Evo N400c Laptop Battery You can improve the life of your Compaq Evo N400c Laptop Battery by doing the following:
When you first receive your laptop battery charge it fully for at least 6-8 hours and then discharge the battery fully by using your laptop unplugged from the mains until it runs down completely.
Repeat this 3 times to ensure your Compaq Evo N400c Laptop Battery will give you the maximum performance.
If you regularly use your Compaq Evo N400c Laptop on mains power for extended periods, removing the battery from your Laptop during these periods will extend the usable life of your laptop battery.
Apr 05, 2008 | Compaq Evo N400C Notebook
Evo n400c
yes it is possible
if you have operating system of xp than it will install automatically if its not done
then first you should install the driver. then you can use it.
Jan 16, 2008 | Compaq Evo Notebook N400c
Computers & Internet Logo
221 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
