Programming My copier has lost it's programming. This happens about once a year. I could not reach my regular repairman this time. The last time the copier lost it's programming, he was able to talk me through the programming over the phone. I wrote down some of the instructions, but apparently to all of them. Can you describe how to get started. The "error code" showing is C 01. thank you my E-mail address is droettger@indy.rr.com
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Here is the error code : "C01" Abnormal operation of the copier main motor although I don't remember how to clear exactly, I beleive you need to turn off the copier hold down either 0&5 - 0&6 - or 0&7 and turn on the copier to get into the service mode
one is for adjusting the light and dark copies' one for adj the settings, and one to clear codes.
Posted on Aug 11, 2008
How can I program a key fob
GRAND PRIX KEY FOB PROGRAMMING INSTRUCTIONS Transmitter Programming No Tools Required In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver.Up to 4 transmitters may be programmed Important Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver
Apr 22, 2013 | 2001 Pontiac Grand Am SE
Every time I have a power failure, the timer stops working and I have to reset all the programs. I thought there is a battery built in to protect the programs during power failure. Why it is not working in...
Timer is not identified.
Copy following link to help identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Most modern digital timers have programming back-up that lasts indefinitely in memory until timer is reset.
However current time is sometimes lost with low battery or power outage.
In some timers there is rechargeable battery that protects all settings. This battery is non-replaceable, and can last a few years or more-less.
Since the market is changing rapidly, who knows what remarkable innovation will lessen quality, causing shorter lifespan of product.
Most timers have limited 1 year warranty against defects in workmanship.
Nov 24, 2012 | Hardware & Accessories
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
Vip 722 looses programming
Jeff Koryciak,
I apologize for any frustration with the recordings being deleted. Signal loss doesn't affect the recordings already on the hard drive, however if it's deleting every day it sounds like the hard drive is about to fail.
We can definitely send you a replacement receiver. I would also recommend using an External Hard Drive to backup and store recordings to avoid losing them in the future. If you would like me to look into a replacement, you can shoot me an email at thomas.faust@dish.com.
Tommy Faust
DISH Social Media Representative
Jun 14, 2012 | DISH Network Televison & Video
How to program new remote to alarm
TRANSMITTER PROGRAMMING Note: System can learn up to 3 different codes max. 1. Turn Ignition ON and OFF 3 times quickly, leaving it ON the 3 rd time. (ON/OFF, ON/OFF, ON) You should hear (1) short chirp. 2. Push the Program/Override Button for 5 seconds until the siren chirps (3) times. Release the button. The system is now in programming mode. 3. Press Button #1 on new transmitter - siren will chirp to confirm programming. Repeat Step 3 within 5 sec. for up to 2 additional transmitters. 4. Turn off Ignition. Note 1: If only one transmitter is being programmed, continue pressing button #1 until dash LED flashes goes out and the system chirps to exit programming mode to prevent unauthorized codes and noise from entering the system. Note 2: Programming mode is exited automatically after 5 seconds of last code transmission or once 3 new codes have been programmed. The LED will flash (4) times indicating program mode exit.
Jan 12, 2011 | 1Way Remote Transmitter
I replaced battery in my audi 80 2.0 tdi but have lost the remote and alarm wont stop going off .
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction: Alarm LED in rear fog lamp switch illuminates for 30 seconds when vehicle is locked.
How
NOTE: A maximum of 4 keys can be programmed (one at a time).
As memory positions of existing keys are unlikely to be known: Obtain and reprogram all keys.
NOTE: Existing key memory positions will be overwritten.
Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Using first key, press unlock button once (programs memory position 1). Alarm horn sounds once to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF. To program remaining keys into memory positions 2, 3 and 4. Carry out the complete procedure below for each key: Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Press unlock button at 1 second intervals, as follows: Twice for memory position 2 (second key). Three times for memory position 3 (third key). Four times for memory position 4 (fourth key). Alarm horn sounds once every time unlock button is pressed, to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF.
NOTE: Ignition MUST be switched OFF between each key programming procedure
Jan 10, 2010 | 1992 Audi 80
Amana French Door fridge not cooling
you have a problem here
you need to get the secondary defrost kit installed
it is not the jazz board
unless he is not programming it right aftwer install
but check your back wall for frost
if you have frost you have an airflow issue
whats happening is the door is being left ajar even a 1/16 gap is an issue
when hot air enters the unit fromn the gap it condenses on the diverter behind the freezer wall
after a few weeks it builds up enought o cause problems
there is a kit you can get that will divert electrical heat to the diverter and keep it warm enough to defrost it there by never having the issue again
Oct 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
I want the security feature to the remote disabled how do I do this?
To de-program the RKE fob from the 1st truck ( the 1998 one ? ), enter programming mode. I had to try 3 times on my 2001 to enter programming mode, and thought I did it the same each time, obviously I did not, so do not give up if you do not enter programming mode the 1st time.
Once you enter programming mode ( locks cycle ) wait 30 seconds, and programming mode should exit. Entering programming mode for the RKE fobs erases all previous RKE fobs.
This should cure the problem with the RKE fobs being programmed to 2 different trucks.
The RKE ( Remote Keyfob Entry ) is not a security feature, just a convenience item, so you are not disabling any actual security item.
Oct 06, 2009 | 1998 Ford F150 Regular Cab
Casio 3708ER
Hi.
It sounds like you have lost all of the programming from the machine. Have you had the machine regularly serviced? If the internal battery hasn't been changed in the last 4 or 5 years, then you have probably lost everything. Since these machines are so old, it won't really be worth spending any money or time on it. Most parts are very worn in this model now, so you will soon be looking at print head or motor failure. There may be a lot of programming to go back in, and it would need to be stripped down for battery rplacement. You would be better off to buy something newer for the same price as the repair.
Mark
Oct 09, 2008 | Casio Parts Cash Register PC Desktop
81 people viewed this question
jasbo
jasbo
