Question about Acer Computers & Internet
PC is 10 days old and it died last night ... No Signal comes up on the monitor
  • lmlayman Aug 10, 2008
    Hi Tbird ... power supply is fine .. have other things also running off that power strip ... it is turning on ... it just wont boot up ... monitor reads No Signal ... also have done the suggestions that you made to no avail ... as you can imagine I am quite unhappy over a new PC that has something wrong with it ... thank you very much for your reply.
  • Acer Master
  • 3,051 Answers
If you have a waranty use it if not check to see that the power supply in the back of the computer is working if not check to see that the plug in in the wall has power plug in a fan or somthing into it if it has power but the power supply still does not work you might have a bad power supply try to unplug the power cord from the computer and press the power switch for the computer and look to see if a light blinks then wait a few minutes and plug in the power cord back into the computer and try to powewr up the computer and see what happnes if nothing sorry to say but you need a new power supply please let me know ok i can help you more best regards mike
Posted on Aug 09, 2008
  • 2 more comments
  • Michael Thomas
    Michael Thomas Aug 10, 2008
    are there any beeps at all ie 3 beeps ect ect
  • Michael Thomas
    also is there a installed video card on the board
  • Michael Thomas
    Michael Thomas Aug 12, 2008
    how is it going have u got it working yet
  • Michael Thomas
SOURCE:
My iPhone 4 is a few months old and last night it suddenly stopped charging. Of course i didn't realize it until my phone died during the day today and i tried plugging it in and wouldn't ch
The charge adapter maybe faulty.
If your cell phone is a few months old, then it would be still under warranty. Take it back to the place where you purchased it and have it repaired or replaced under warranty.
Jul 26, 2012 | Apple iPhone Smartphone
I own an ASUS VW224U - Manufacture date is March 2009. Purchase date 4/10/09. Last night i was playing L4D2 and after the game it just powered down. I rebooted my PC, Disconnected it over night. Tried a...
Does your ASUS power on? If it does then your computer power supply is good, and if you computer doesn't boot but you can hear power going to the power supply, then your video card has died and a replacement for your video card is due. The "ticking" noise could be your video card cooling off. But your question was a bit vague, I could not tell if your issue was a power issue with your computer or a monitor problem.
May 01, 2017 | ASUS VW224U 22 inch Monitor
I have a Dell E171FPb monitor and the brightness display pops up and won't go away unless I turn off the monitor and turn it back on. Within a few minutes it pops back up again. The controls on the...
no there is no such thing as display driver.
the monitor is bad, if the buttons are dead.
my guess is one button is stuck on,.
that monitor can plug in to any PC made with no drivers at all.
special.
only resolution matters, set that to.
1280 x 1024 at 75 Hz (60 to 75Hz)
test the monitor on 2 PC, if its bad its bad. end story.
surely you have access to 2 PC, the bad PC and one known to be good. and DO not set resolution above the above.
or it will fail. its old.
it is now 16 years old
time to upgrade no?
most if not all 16 year old monitors the CCFL black lamps
died 10 years ago, my guess is yours sat parked for 10 long years
never run all day ?
Jan 27, 2018 | Dell E171FPb 17" Flat Panel LCD Monitor
Worked fine last night, discovered it this morning still turned on but no signal to monitor. Rebooted and it began a consistent beeping with no signal to monitor. Unplugged several times to no avail....
the beeping is coming from the cpu.
1 unplug pc
2 pull out ram chips
3 use an eraser to clean the gold, yes thats gold
what happens is the gold on the ram oxidizes and does not connect properly and can go bad but cleaning it with an eraser sometimes works. take a cpu that is working unplu it pull the ram and you will see the same thing your other pc is doing.
4 reinstall ram (correctly)
5 boot up cpu
6 please vote.
Dec 13, 2010 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
My computer will turn on but my monitor does not get a signal and I've tried this on two working monitors and two different power chords. The lights on the keyboards don't even work. Any solution?
I was just dealing with this last night. My pc would come on, but I kept getting a "No Signal" message on my monitor. I first plugged the machine into a known working monitor. It worked fine so that eliminated the video card issue. Then I plugged the monitor into a different computer...it too worked. So I knew that the monitor was good. I then switched the cord from the faulty monitor and still didn't get a signal. I proceeded investigating the issue. I found that if you boot the machine in safe mode, it actually caught a signal. So...I figured it must be something to do with the resolution. My solution: Boot the machine in safe mode, change the resolution in the control panel and reboot the machine. If it doesnt catch the signal booting in safe mode, I suspect it is a faulty video card. You are likely to find what you are looking for online at zipzoomfly.com or newegg.com
May 20, 2010 | E-Machines eMachines Desktop PC
Power light blinks but the screen is black and won't come on.
is it an LCD monitor?
if so then it's more than likely the backlight tubes or the backlight tubes inverter supply has died is it fixable but i am not sure how much it will cost you at your local repairer and monitors are so cheap these days its probably not worth it!
hope this helps,ben
Aug 13, 2009 | Computers & Internet
ACER 6920G COMPLETELY BLANK SCREEN BUT LIGHTS COME ON + HDD
Ihate to be the bearer of bad tidings but the Motherboard CPU has gone to rest, and you should look into another laptop.
Jun 27, 2009 | Acer Aspire 6920 Notebook PC
Says no signal on monitor.
The monitor is telling you that it is functioning properly (it works). It is also saying that it isn't receiving and signal from a computer. This can happen when-
** computer is turned off but monitor is on (this can occur, for example, when the computer's power supply dies while turned on). That happened to me just a couple of days ago.)
** monitor cable to computer has come loose or totally disconnected
Jun 21, 2009 | E-Machines eMachines Desktop PC
Lg1932 monitor died
same thing just happened to me, fine last night, no power in the morning, why!??!?!?!?! I'm very upset, obviously this is not an isolated incident!
Sep 19, 2008 | LG L1932TQ LCD Monitor
19 "lcd gateway monitor will not power on.
Have you tried your monitor on somebody else computer?
Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
43 people viewed this question
Ekse
Alun Cox
