Question about Jenn-Air Kitchen Ranges
Was low temp roasting of ribs in Jenn Air JMW9530AAB convection oven. Heat webt ofand stove started to beep and displayed "-F7-". Cancel failed to do anything. Shut power off and when turned on again. The beeeping resumes and the display shows "-F7-". After 15 to 20 seconds beeping stops, and display now shows time and "F1". Beeping then resumes in a few seconds. All oven controls are inoperative. Microwave oven on same circuit is operational.
  • wfoconnor Aug 09, 2008
    I had tried that and it didn't work.
    Genius:
  • 1,665 Answers
Its wire harness must be checked (wire condition, bad or loose connections, ground connections etc.) Some experience is needed in electrical circuit repair otherwise better call a tech to troubleshoot and repair it.
Posted on Aug 09, 2008
    Master:
  • 623 Answers
I think ginko is right...you should replace whole panel it will be easier for you
  • Jenn-Air Master
  • 19,396 Answers
It is a short in touchpad , you need to replace the touchpad, to find part go to http://www.repairclinic.com/referral.asp?R=154&N=696191
    Brigadier General:
  • 3,614 Answers
The electronic control may not be set correctly. If the control is not programmed correctly the oven will not start and you will usually hear a series of beeps instead of the microwave starting. See your Use & Care Guide
  • micromaster
    micromaster Aug 09, 2008
    which one you have tried....? Solution #1 - or - Solution #2
  • micromaster
    is my solution was wrong or not really specifying what really the problem is coming..?
    Look at your solution you said:
    It is a short in touchpad , you need to replace the touchpad, to find part go to http://www.repairclinic.com/referral.asp...
    may i know wheres that touch pad you have said can be seen on microwave?
SOURCE:
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
Beeps and flashes F1 while trying to use covection roast
Usually this is a failure in the electronic control. We rebuild a lot of these.
Best Regards,
Bruce
www.fixyourboard.com
Jun 12, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Convection cooking
Convection ovens are great for roasting!
I cooked a 15 lb  stuffed turkey in 2 hours in mine. And it was juicy and fab!
My auto degree set for convection  is 325.
I have a Jenn Air wall oven, so I don't know, it might be different for different brand.
Roast or bird should be in the middle of the oven. THe air has to circulate well to get best results.
I believe rule of thumb is a convection oven takes 1/2 LESS time than conventional.
Hope this helps.
Jan 13, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Convectin fan in Jenn Air Stove
sounds like the fan or motor is not working at all. have a technician replace it.
Mar 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Kitchen Ranges Logo
329 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
