Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer My dryer won't tumble. It has heat and it sounds like it has power going to it, but when I push the start button it won't turn.
  • lvs2read65 Aug 09, 2008
    My dryer won't tumble. It has heat and it sounds like it has power going to it. When I push the start button I hear a clicking sound but it won't turn.
  • lvs2read65 Aug 10, 2008
    Thank you.
    Welcome Back:
    Visited the website for 2 consecutive days.
I just put a new belt on. something is hanging it up.
Posted on Feb 27, 2009
Your dryer belt is broken. I just had the same exact problem. You need to replace the belt.
Posted on Jan 09, 2009
  • Whirlpool Master
  • 3,051 Answers
If u can turn the drum by hand than more than likly the belt is bad or there may be somthing stuck in the edge of the drum ie kids toys ect ect or the motor for the drum has failed unplug the unit if you can take off the rear cover you should be able to see the belt that goes around the drum or you should see the motor for the drum check to see if the belt for the drum in inplace if not get a new belt and if the motor can turn by hand buit it wont turn the drum check to see idf there is a red button to reset the motor if not than the motor is probably bad check to see if you still have a warranty good luck keep me posted best regards mike
Posted on Aug 09, 2008
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Troubleshooting whirlpool electric dryer WED5530SQ0
The only thing that is left is the timer. Use a multimeter and wiring diagram prior to replacing it. It is something that doesn't go out often.
Good luck.
Semper Fi,
Z
Feb 01, 2018 | Whirlpool Dryers
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
Whirlpool duet does not turn on when the power button is pushed no lights come and no sound the interior light works and then theres the odd time you push the power button and it works fine
sounds like the door switch/latch is going bad. You can test it here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 26, 2010 | Whirlpool GEW9250 Electric Dryer
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
162 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
