Question about Acer Aspire 5520-5908 Notebook
I have a problem with my sound
I uninstalled the sound drivers and reinstall and the sound is still low ,even when i turn the volume all the way. Is there a defect in the sound cards on some of these machine?
If playing a DVD unfortunately VISTA limits teh sound ... sucky i know.
Posted on Oct 25, 2008
    President:
  • 2,961 Answers
Have you installed the correct driver? , because Vista uses Realtek HD Audio and XP uses Standard Realtek Audio, also right click on the speaker icon>audio properties and make sure that speaker volume is set to the correct speakers and not headphones or somethong else
Posted on Sep 03, 2008
Cannot able to create sound
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
Jan 28, 2011 | Creative Labs CT4870 / CT4780 Sound Card
When i press "matrix" i hear no sound coming out
you might try uninstall both the sound card and its drivers then restart your computer before reinstalling them only do this if your sound card and its drivers have these on a disc
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
Jan 25, 2011 | Logitech X-540 Computer Speakers
All of a sudden, the sound level became very low
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
hope this helps
Jan 12, 2011 | Logitech X-240 2.1 Speaker System with MP3...
I can only hear a faint sound from the speakers even when all the volumes are turned up. Where can I go to look for the problem?
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 12, 2010 | Logitech SoundMan S-20 Computer Speakers
Sound so low,can not hear it even with the volume control on max. I can not hear any sound on speakers unless I use the earphones but it also too low.What can I do?
Check the volume control within Windows.
  • Look at the bottom right corner of your screen, a double click on small speaker. (In system tray). If you can' t find it, then click small left arrow next to it. You will find it there.
  • A window opens make sure the volume is set to maximum.
If issue is still not resolved then, reinstall and update the driver.
Here is the link, you may download and reinstall the drivers.
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=DIM_PNT_P4_3100&hidos=WW1&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
If none of this works, then do system restore, the system to date it was working fine.
Links explaining steps of system restore, following link explains all. http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
if you wish to research bit more, I am providing you with two more links.
http://support.microsoft.com/kb/302796
http://support.microsoft.com/kb/306084
Please rate as per level of assistance by me. Thanks :)
May 22, 2010 | Dell Dimension 3100 PC Desktop
Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Aug 04, 2009 | Creative Labs Gigaworks S750 Computer...
Sound is low
try to see if the wave volume is on and maximum on the volume panel ( double click on vol icon on tray system (right low) ) ...also see if your speakers are plugged into the proper place ...and are not in the auxiliary out or something like this ...they should be plugged into the green middle out ...if they are simple stereo 3,2 jack ...so ..if the problem its still on ..its probably the sound card...(actually the pre-amplifier on it ..)
Aug 03, 2009 | Dell Dimension 3000 PC Desktop
No sound out of laptop
Try uninstalling and reinstalling the audio drivers. Good Luck
Jul 29, 2009 | Computers & Internet
Low media player volume
Hi there... You can reinstall the sound. First uninstall the driver then reboot then install it...
Mar 09, 2009 | HP Compaq Presario C700T
The sound stops on my lap top
It sounds like the drivers were uninstalled. If you uninstall the devices in device manager that are in alarm XP will try to reinstall them when you reboot, sometimes it will just reinstall them on it's own, but you will probably need to have the drivers handy.
Nov 23, 2008 | Computers & Internet
Acer Aspire 5520-5908 Notebook Logo
184 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
