Question about Whirlpool GEW9200L Electric Dryer
Dryer not getting any power
I have a whirlpool duet dryer model number GEW9200LW1.  I am not getting any power to control board, nor is the inside light coming on.  I checked the breaker and it is on.  Also, the washer is getting power.  I had researched earlier and checked the thermal fuse and there was a dime that was resting on one of the connections.  Apparently it had been there for a while because half of the terminal was burnt through.  I went to sears and replaced the thermal fuse, then plugged it back up and still not getting any power.  I bought a multimeter and checked for continuity at the plug and it worked.  I'm afraid the dryer has shorted out.  Is there any other fuses that may be shorted out or will i have to replace entire electrical boards.  Please Help.
thanks
James Peters Northport, AL
  • jpeters8434 Aug 12, 2008
    I have ordered the main control board and it should be here in about 4 days so I will update when I see if it is the problem
  • Anonymous Sep 11, 2008
    Same problem only ours was a quarter. I'm assuming it the control board cause everything else has power and all disc and fuses check out.
    Whirlpool needs to be notified of this problem. I'm going to cover the thermal fuse with electrical tape to prevent this from happening again.
    150.00 for a new board????
  • 869 Answers
Replace the main Control Board,
Posted on Aug 11, 2008
SOURCE:
My whirlpoolduet dryer is on control lock how do I unlock it model # gew9200lw1
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet however, your whirlpool duet needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Dryer GEW9200LW1. Problem: When start button is pressed, you can hear motor relay clicking. I changed the elect. control board, no joy. I've checked motor circuit according to...
so you started first by checking the dryer door switch correct? then if you had a multimeter you would check that power does come in from the wall and goto the board then leaves the board and goes to the motor as well and also goes to the timer as well Do you have any error codes at all?if the dryer door switch is bad this could be why your motor is not starting please message me back with your reply Thanks again Rick
Dec 22, 2010 | Whirlpool Dryers
Whirlpool duet dryer model # GEW9200LW1, when powering up goes directly to touch up, and will not start. thermal fuse ok
Dirty moisture sensing strips? Have you tried cleaning them with windex?e03f8f0.jpg
Number 34 these measure resistance by picking up wetness from the clothes. Dryer sheets can coat these with a non penatrable film which fools the brain into thinking them clothes is dry so it moves towards the cooldown mode and shuts off with wet clothes. Clean them sensor strips real good and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 11, 2010 | Whirlpool Dryers
DUET DRYER MODEL NO. GEW9200LW1. DRYER WON'T SPIN. CONTROL PANEL LIGHTS UP, TIMED DRYING SELECTED, HOLD START BUTTON DOWN AND NOTHING HAPPENS. ALL I HEAR IS A CLICKING NOISE AT LEFT REAR OF DRYER. IT...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
I have a whirlpool duet model GEW9250PW1 DRYER The display screen wont light up and there is power going to the unit I can hit the security lock and that indicator light comes on but that is the only...
sounds like the control board is out. If you remove the lower front cover a hex head screw in each corner, there should be a plastic pouch with tech sheets inside run test #1 part number for the board is 8546219
Oct 02, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Does anyone have any idea when a Whirlpool Duet GEW9200LW1 Dryer was made? Trying to get an idea on a used one that I'm looking to purchase.
The model number tells only the year that model is introduced but the serial number tells the year and the week of production.
Sep 30, 2010 | Whirlpool GEW9200L Electric Dryer
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
254 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
