2000 Oldsmobile Bravada Logo
Posted on Apr 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When driving my 2000 Olds Bravada, it has a loud roar noise that sounds like when a semi truck is taking off before the gears are shifted. Transmission shifts easily into gears, just this loud roar noise all the time.
Anonymous
Level 3:
Guru:
  • Master 1,705 Answers
  • Posted on Apr 22, 2011
Anonymous
Master
Level 3:
Guru:
Answers
1705
Questions
Helped
402488
Points
5112
If there's a loud roaring noise all the time, then your muffler probably has a hole in it, time to get a new full or partial exhaust pipe.
If the noise goes when it changes gear, then you've probably got a gear box or thrust bearing problem.
What is a roaring loud sound in front of 2000 chevy cavilier
Bad front wheel bearings will make a loud roaring sound, and get louder as time goes by, check this out! God-Bless!
Making loud roaring noise when driving. no warning lights no trouble with gears shiftting that i notice
A loud "roaring" noise as you describe it could very likely be a bearing going out.
2helpful
Roaring noise in front of 2003 olds alero gets louder as I accelerate, sounds like manual transmission needing to be shifted to next gear(this isn't a manual transmission
Have a shop look at it. It may just be a failed wheel bearing. The bearing will leave you stranded if it gets bad enough and cause more damage.
Grinding noise on 2002 Olds Bravada
Try making tight turns to the right and then to the left. see if the grinding noise comes and goes. It could be your C/V joint and they need to be replaced. The noise will only come when your making the tight turns, you don't have to go fast. Walking speed will do and you can hear it with the window open or someone walking beside the Bravada. Good luck and keep me posted. Be glad to help.
2001 Olds Bravada noise from rear axle when driving
you may be low on gear oil...have someone check it for you before the rear end locks up
1998 olds bravada tranny
AWD should not be effected, but sounds like you do have problems.
2000 Nissan Maxima sounds like its not shifting into 3rd gear
What do you mean by loud... Loud where??? If noise is from engine, make sure that the mechanical fan clutch is not "locked" (it's supposed to freewheel when cold... if it does not, it will "roar" when driving.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
