Question about Bose Wave Radio
Bose wave does'nt display light ' can't see the time, Help
Display light
  • MoBarbaro Aug 11, 2008
    Light that displays time and radio station etc. LED light only illuminates when you turn it on and off then it fades to black! I replaced the 9 volt battery. HELP!!
  • ishelbyfree Sep 03, 2008
    my led on by bose is so dim at night i cannot see it. you offerd a repair solotion for the one that has a cd but mine does not. any suggestions. thank you
  • 3 Answers
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Posted on Oct 06, 2008
    Problem Solver:
  • 5 Answers
This happened to me because my daughter was messing with my wave radio...just hold the CD MODE button and press the on/off button and it will be fixed. It was driving me crazy! Such an easy fix!
Posted on Oct 01, 2009
Press the CD mode and the volume button.
Posted on Feb 13, 2010
I believe I read that this is a selectable mode that you can get into by holding "CD Mode" down while pressing "On/Off". I think doing this again re-enables the normal mode of the display.
Posted on Aug 12, 2008
You MUST have the system shut off before you can apply this fix.  I had to google the Bose owner's manual b/c I was trying to apply this fix this while listening to the radio and it didn't work.  AND there are different instructions/owners manuals for Bose Radios and the Bose Radios that also have CD players.  My cat steps on the top of my Bose all the time and turns on the radio and messes up the presets and displays which is what caused my clock display to disappear.
Posted on Feb 27, 2010
I tried some of theabove and didntwork. so I changed battery and unplugged radio then replugged and was bright as new..
Posted on Jun 01, 2011
3 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
SOURCE: bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Posted on May 14, 2008
Capacitors to fix dim display wave radio AWR1-1W
Vacuum fluorescent display is worn out .. there is no repair. Replacement is the only cure.
Don Miller, CET
Bose Wave Radio Repair
don.miller60@outlook.com
Nov 30, 2015 | Bose Wave Radio
The time display is dark. the radio works and I can set an alarm but the time display is dark. I seem to remember there is a battery somewhere that may need to be replaced.
it may be that the display died or it not getting enough light on the screen because it has a senor that when the lights turns on it will be brighter or if this does not work call bose at 973 644 BOSE
Jul 10, 2011 | Bose Wave Radio
Every light on my bose wave radio is lit up. How can I reset it
Contact Bose at Bose.com. They will have you send it in for repair.
Aug 28, 2009 | Bose Wave Radio
Dog knocked Bose CD radio off shelve. Doesn't work at all
Does the display light up for a couple of seconds? If so, try holding down the CD MODE and the on/off button at the same time. I hope this helps.
Aug 16, 2009 | Bose Wave Radio
I have a bose awrc1p radio display light changes
This could be the battery causing the display to act strangely. If the radio still works audio-wise, the following should fix the display: The older model wave radios have either a 9v or 3 AA batteries (accessible from the bottom). Remove any battery, and reset the system by unplugging the power cord for about 40 seconds. Plug it back in without the battery attached. If the problem goes away- replace the battery or batteries. (which is only there to hold the clock time, presets etc when not plugged in) BTW- you'll have to set the clock, alarm, presets etc after this procedure. If the problem doesn't go away, call Bose. I think they can repair this for $99 and/or offer a new one as a trade-in discounted.
Jun 12, 2009 | Bose Wave Radio
Bose not working at all
Unfortunately, Bose will not release their schematics of parts lists, effectively giving them a monopoly on repair of these sets. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Jan 28, 2009 | Bose Wave Radio
Clock on Bose Radio
Push & hold Clock Set Button. While holding, push On/Off button,
Thank You, FixYa Community! Thank you! Thank you! Boy, that one was not obvious.
Nov 06, 2007 | Bose Wave Radio
Inoperative Bose Wave Radio
You should contacty Bose directly to find out about service. There may be a fault in the power supply, or one of the circuit boards in the unit. This will require proper troubleshooting and parts replacements.
Jerry G.
Oct 27, 2007 | Bose & Wave& Music System
Bose wave radio/cd
Feb 25, 2007 | Bose Wave Radio
Bose Wave Radio Logo
2,896 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
