Question about Olympus WS-100 Digital Voice Recorder
Power and file problem
Hi my recorder has no power as a hand held device. I have changed the battery 3X without luck. I have tried plugging it into the PC and it does become active. the folders are empty. Please advise if yo ucan on what might be wrong.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Make sure the battery is inserted correctly...else you will need olympus repair
Posted on Aug 21, 2008
Dont know what size battery to use for a nady ht-3 mic transmitte
To insert the battery, You will need to unscrew the below button part of the hand held mic (anti-clockwise), and after unscrewing, you will see the space to fix in the 9 volt battery..
When you buy the battery,before fixing the battery in, check the polarity before placing the battery in (positive + and negetive -)...After inserting,screw back the cover in and locate where the power switch is..It always has an indicator to know if the power is on...
Note..make sure the Transmitter is on for it to be able to work properly with the hand held microphone....
Good luck..
Sep 07, 2011 | Nady Systems HT-3 Professional Microphone
Tip
How to record Guitar sound on a computer
<p>Line-in <br /> <p>1. Buy a software package for recording music, if your budget allows. Recording music software is specifically designed for recording musical instruments formed. He cannot offer features found in common software audio. Alternatively, an audio recording program for free to get the music recording software than your needs and budget. <br /> <p><br /> <p>2. Buying a guitar cable to your computer if you use an electric guitar. Connect the larger end of your guitar amplifier and the small end into the computer microphone / line-in. <br /> <p><br /> <p>3. For an external microphone when a traditional guitar. Plug the microphone into the computer microphone / line-in. A stereo microphone is a natural sounding audio file, due to the dual microphones. <br /> <p><br /> <p>4. Open your audio recording program, which recognizes the device connected to ensure the microphone / line-in. Pull the cord, again if it does not recognize the device. Change the settings for the recording program to your needs to adapt, you can file type for quality change, and the recording is mono or stereo and audio level. Press the Record button, then started playing guitar. <br /> <p><br /> <p>5. Press the "Stop" button when you finish the game. Some programs can automatically be prompted to save the file; others may be the audio file first. Press "control" and saving "S", if not prompted. <br /> <p><br /> <p>Digital recorder <br /> <p>1. Buy a stand-alone digital recorder, if you do not want a guitar cable or an external microphone. A stand-alone digital recorder is small enough to fit in your pocket and can be placed anywhere without the need hampered by a cable. <br /> <p><br /> <p>2. Set the digital recorder on a flat surface. Press the record button. <br /> <p><br /> <p>3. Press the digital recorder, "Stop" when finished. Connect the recorder to the computer with data cable. Open the device by clicking on "Start" then "Computer" and double click on the recorder in the "Removable Devices". Copy the file from the recorder to your computer. Turn off the burner when you are ready to save battery power.<br />
on Jun 21, 2011 | Computers & Internet
Reiker ceiling fan - does not turn on - theres is power to unit - maybe remmote is bad? how do i change code
Before trying to change the code, have you tried changing the batteries? Both in the hand held remote and the one in fan housing? If so, and that didn't help, make sure the batteries are turned in the right direction and fitting tightly.
Will the fan operate without using the remote control?
Feb 19, 2011 | Reiker Room Conditioner Heater
Out of range
Unplug it - take battery out of hand held unit - for several minuets..
Put it back and power up..
If issue still there - there is a channel selector on the hand held unit.. Try changing channels..
If the battery is week in hand held this could happen.. These batteries last around a year +/-.. You can get a replacement online,, WalMart,, Radio Shack..
There could also be interference in the area..
Have a great day !
Oct 26, 2009 | Uniden Cordless Phone
Downloading recordings
HI a quick search reveals that Quick Link is required to transfer Voice memos to PC.
However in the Owners Manual here it dosn't mention it. (Click the link to see the PDF)
The Quick Search link there does have a menu for wav playing Software. But as a USB storage device I would suspect that when you plug it into a computer, and it does it's automatic drive install, the device should pop up as an additonal Drive in the "My Computer" window. Try opening the My Computer, and plugging the device in with the Mini USB cord you have, and see if a new drive icon pops into the window, If so, that's what you're looking for.
The Specs say the device contains four folders that can contain up to 100 files each. They're most likely WAV files.
Good luck with that.
Richard.
Jun 24, 2009 | Olympus VN-4100PC Digital Voice Recorder
Battery not charging
1. plug the power cord into the laptop
2. remove the battery
3. try to power on the laptop
if the laptop led lights up and/or powers up without the battery it can be determined that you need a new battery
if the laptop led doesn't light up and/or power on. then you may have a charging port or power cord problem
Apr 18, 2009 | Dell Latitude D600 Notebook
Can't get the the Jazz DV151 to communicate with my computer...
My wife got the same jazz camcorder.This is what i did to get it to read on my computer.I am running Vista ultimate but im sure this would work for XP as well.I connected the cam to the computer and without batteries i pushed the power button and held for 2-4 sec and voila it found the sd card i had.I am not sure if it works with batteries in it but i figure it should. Hope this works for ya
Dec 26, 2008 | Jazz DV-179 Digital Camera
Frozen?
Its easily fixed. Try this.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Everytime I plug my Sansa e250 in it freezes
You can press and hold the power/menu button for 20 seconds. This will force the player to shut off. Restart it, if you are still having problems, try the following. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 22, 2007 | SanDisk Sansa e250 MP3 Player
I can't delete files off of my mp3 player!
Hi, This is taken from another post, but might work for you as well: 1. Take the battery out of the Sansa player. 2. While the battery is out, plug the Sansa m200 player into another USB port, preferably a rear one or a self powered USB hub, on the computer. 4. If the screen reads ?USB Connected? when the Sansa player is plugged in with no battery, unplug the Sansa player. 5. Hold the "Menu Button" (Power Button) for 45 seconds. 6. Connect it to the computer again (still without the battery). 7. If the screen once again reads ?USB Connected,? disconnect the player and insert a new battery which has never been previously used. 8. Try powering on the player. If the above procedures (power cycle) didn't work, please repeat the process again but now hold the power button for 2 minutes and wait for at least 5 minutes before plugging in new set of batteries.
Jan 12, 2007 | SanDisk Sansa m240 MP3 Player
Olympus WS-100 Digital Voice Recorder Logo
60 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
