Chamberlain & Liftmaster Garage Doors Logo
Jim Tench Posted on Apr 22, 2011
Garage door worm and drive gear were replaced. Evrything appears to be replaced properly, but even without the chain on, the door moves only a few feet then reverses.I checked to be sure the motor shaft was pushed out as far as possible before tightening the collar.
STEVE WOLFINBARGER
Level 1:
  • Contributor 504 Answers
  • Posted on Apr 28, 2011
STEVE WOLFINBARGER
Contributor
Level 1:
Answers
504
Questions
Helped
260008
Points
97
Sounds like the rpm senor may have be out of place - the fingers on the cup must break the field between the sensor pickup
Garage door moves few inches and stops, springs are fine, sensros are fine.
If it is not blinking when it stops, then the capacitor is blown. Replace the capacitor and it should resolve the problem.
Replace the gear and sprocket assembly on a garage door opener
I had to retension my spring assembly on the garage door a few years ago and I don't recommend anyone without proper tools and some experience to do it. It can be dangerous.
Installed new worm gear, but now i cant get the door down
Check to see if the 4 wire harness is hooked up from the limit assy.
1helpful
2answers
Craftsman Garage Door Opener Won't Open
When mine did this, it was because the nylon gears that drive the chain had stripped. My wife had to live without the opener for a week or more, but I was able to find a new gear kit online and replace the damaged gears. It wasn't difficult.
The other option is to buy a new opener.
3helpful
3answers
Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
I have the same problem. I just removed the cover and discovered a nylon gear had been worn out. I found lots of shavings inside the cover. The nylon gear is beneath the exterior chain gear. I am looking for information on how to replace it, if I can find the part. If you decide to look at yours, unplug the power and remove the sheet metal screws securing the bottom portion of the cener cover to the front and back covers. Then just remove the upper screws from the center cover. Good luck.
Top Chamberlain Building Materials Experts
Jose Ramirez
ADMIN Andrew
ADMIN Andrew
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
