Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Waterfill keeps filling
I replaced the watervalve because of hard waterbuildup and now that i have evrything back together the water keeps filling to overflow and never reaches the agitate stage. I can move the dial manually. close the lid and have the water spin and drain so water drainage isn't an issue Any suggestions? Thanks Todd
  • 943 Answers
Hi todd it looks to me that the problem with the water level control or the small level control hose hard water &lint can sometimes clogg this hoe up remove hose from switch and blow into it hard if its clogged you will not be able to blow clean it and try if it does not work after its clean replace water level switch thanks the appliance doc
Posted on Sep 17, 2008
Maytag washer atlantis
This is usually caused by the lid switch. These are inexpensive and easy to replace. There are videos at http://appliancehelponline.com/toplidswitchvideo.html that will walk you thru testing and replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Jun 04, 2010 | Maytag Atlantis MAV6451 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 - The machine buzzed and stopped. Now it wont run. Dont think its the lid switch
does it fill with water?
Does it not do anything after it fills?
If this is the case than it is most definitely the lid switch.
I recently had the exact same problem. Easy fix if you are handy.
Remove back of control panel to access the mounting screws. this will give you hand access to the lid switch. Try manually activating it after letting it fill. Replace switch or repair if able.
Good luck
Sep 30, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Water will not drain, will not do anything.
I would check the lid switch. That is most likely the problem.
Apr 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
I have a maytag washer # LAT 9593 , washer fills with water very
Take off your hoses and check filters for sediment build up. If this is ok, you may need to replace the water inlet valve.
Feb 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Our maytag will not drain or spin
Check if the lid switch is working. If not see the solution proposed on this blog.
Aug 16, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Atlantis water fill level
is it a pressure switch control,with a rubber/plastic hose.or is it electronic control.if it the first check the hose is still on or that the switch clicks when you gently blow into it.if its electronic it may be a board problem.
Mar 01, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Fills with water than nothing!
Most likely it's the lid switch, part number 22003804.
Remove the back of the console to gain access.
Jan 22, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
115 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
