Question about Kenwood KW85 Air Conditioner
Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
  • 1 more comment
  • Anonymous Mar 18, 2014
    I have an e3 fault on my remote control of my split ducted a/c
  • Anonymous Mar 28, 2014
    why e3 showing in remote and ac is not working
    showing e3 in remote and ac is not working
    New Friend:
    Problem Solver:
My air conditioner in turning on give E3 error.
Posted on Dec 21, 2014
    Master:
  • 521 Answers
It indicates the problem of a compressor as the fan works fine .i feel the compressor is not able to cool the device.i will suggest you to get it checked by a proper technician.
Posted on Aug 09, 2008
  • Kenwood Master
  • 19,396 Answers
Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
  • Ginko
    Ginko Aug 09, 2008
    Try also turning off the general power switch for five minutes, this will reset AC control board.
  • Ginko
    Ginko Aug 09, 2008
    On some model the button is indicated as clear or reset, try cutting power off often it works.
Voltas split a.c error code e3
http://errorcodeairconditioning.blogspot.com/2012/06/chigo-fault-code.html
LED
code = E3
explain = display at off state
LAMP DISPLAY
code = flicker 3/5 SEC
explain = display at on/off state
FAILURE = coil temp. sensor fault
The reason of fault and solution = 1 .Check whether the resistance of the sensor is normal
(the resistance is 5K? in the normal temperature 25°), when it is abnormal the sensor should be replaced.
2 .Check whether there is short circuit or open circuit in the wire of the sensor, and whether the plug is connected well,
3.When the 1 and 2 are both normal, then the components or integratedcircuit is damaged, the electric control board should be replaced.
Apr 29, 2016 | Heating & Cooling
E3 Error Message
E3 indicates a sensor fail - most probably the humidity sesnsor. Or it could be a fault in the display itself. Are all the functions working properly?
May 28, 2013 | Humidifiers
The e3 light is on and its not cooling just fanning
The E3 error code, indicates that the water in the collection tank is full and needs to be emptied.
Turn the unit OFF & unplug it, before attempting to drain the tank. Once that is completed, the unit should operate as designed.
Hope this helped you and thanks for choosing FixYa.
Sep 07, 2011 | Royal Sovereign ARP-4010 Air Conditioner
I have E3 showing up on my Conia air conditioner an cannot find the booklet that came with to find out how to fix it ???
Please check one of this:
E3 Fault room sensor(s) (open or closed circuit)Code
E3
Error detail Remote control transmission error (transmitting error)
Inspected unit Remote control.
Dec 10, 2010 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Error : E3 FAULT
i have problem ac indoor come on display e3 error problem kindly give me solution
Sep 16, 2008 | Kenwood KW85 Air Conditioner
Fault E3
Oct 28, 2007 | Kenwood KW85 Air Conditioner
Kenwood KW85 Air Conditioner Logo
925 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
